Door stuck shut need help
ediddily
Nevada
07 expedition xlt
The driver side rear door outside latch doesn't work (wife heard something fall inside) plus the child lock is on so I can't open the door from inside or outside. Does anyone know how to get it open?
If I roll the window down, can I use a coat hanger to open?
Don Hall
SANTA CRUZ, CA
From several Google posts regarding this subject, it seems the only solution is to remove the door panel, and service the lock.
E
ediddily
Nevada
i am aware of the requirement to remove the door panel, but can the door panel be removed with the door stuck shut?
E
ediddily
Nevada
Thank you, this lead worked!
For those looking for a solution for the same problem.
-Note the location of the child lock based on the other door and the unlock position
(Mine was at the same level as the arm rest and unlock is down)
-From the inside, pull back the weather strip.
-Use a long flat blade screwdriver. (I used a 9")
-Stick it straight down between the door and the body trying to smack the lock lever.
-Work the screwdriver up and down and few times.
-Check to see if the door opens
-If not, repeat previous 2 steps.
You can do it, I did.
