mquick5
@JExpedition07
My 3rd gen xlt has rear power side vent windows.
@JExpedition07
And less likely loose dogs can jump out when you load stuff.Ventilation for the dogs (crated) when parked.
In my case it helps when I buy groceries. When I get home, if I open the back, usually something will fall out on the ground. But if I open the glass first, I can either retrieve some things or push them back so that when I open the back, they won't fall out.
I use mine all the time. Unfortunately, this thing is so tall, it's pretty hard to reach anything unless it's pretty packed.
I use mine as the escape hatch it was meant to be when zombies, or "mostly peaceful" protesters surround the car; so i can surround them with my weapons (which I since all lost in a boating accident).
You too? lost mine overboard 15 miles out in 800 ft of water...
I have yet to use it one time in a year
I have had little use for it currently, as it is not designed to be open when moving, unless lashed to whatever is sticking out the back. That being said--I would never just want a completely sealed window/hatch. You never know (as the above poster stated)
As a list of the many things Ford should do for the Expy, an electric window that goes up and down should seem to be one of them.
As an aside, a LC rear opens up like a clam (don't know the proper name for that) and you can sit on the tailgate, properly.
YMMV.
