Engine Won't Turn Over
JonnyQball79
Washington
Help, I have an 03 expy with 215,000 miles and a little bit of water loss. Today, came out and the motor wouldn't turn at all. Battery would grunt and then stop, but had power for the radio. Motor would just grunt a second and then nothing. Whole trip car never got past middle of temp gauge and no smoking either. I'm hoping its not seized.
Plati
battery low?
big pool player Johnny?
i have a collection of cue balls in my pool room
nice rack too ... favorite cue is far left, i call it "Fa"
RichardH
TX
Could be battery, could be cables/connectors. It's usually a combination of small things = problem. I went through a stall problem about a year ago. Always stalled when driving.
I guess I would just toss a new battery in there. That's an inexpensive start.
riphip
Memphis, TN.
May be hydro-locked. You did say some water loss. Remove plugs and see if it will turn over by hand (crank pulley/harmonic balance bolt). You can bend a rod trying to turn over with starter if hydro-locked unless plugs are removed.
Yupster Dog
Moderator
Charge the battery first. If the battery wont hold a charge then get a new one.
Then after you have a stable 12 volts do a voltage drop test, it could lead you to the problem.
https://www.expeditionforum.com/threads/voltage-drop-testing-for-no-start.26144/
Bilsto
Nashville TN
I haven't had this problem with mine, but it could also be a starter too. The heat and environment could have finally just caused it to fail. But the other guys are right about starting with the battery, I'd pull it and get it tested. That would be the easiest thing to try first.
CountrySplatt
Hutto, Texas
On my 2004 EB, I had to completely rebuild the positive terminal on the battery to get it to reliably start. Evidently, it will get warm and loosen, and then acid will eat through it in a jiffy. Drove me nuts because all of the junkyard trucks I could find, had the same problem. Similar symptoms you describe, too...radio worked fine, lights all worked, would make a turn and then go dead and click at me. I jury-rigged it with a pair of vice grips ensuring I had a connection on the battery terminal to troubleshoot a little.
Kicknbak
Kerrville, TX
My battery charger has the "Boost" selection on it and sure aids in quick battery trouble shooting. I can even get it started with a bad cell. Nice because you can then drive it to the auto parts store and let them free test the whole system and even swap the battery out... for free.
Plati
Isn't the first step to try jump-starting it from a good running car?
That could be a first step. I like to collect information ... like current battery voltages (resting, during start, fully charged, running, etc) and go from there. Helps you get to root cause vs just start driving again.
