Nice job, I love the look of it - does anyone have any ideas for the same thing but on a 3rd gen (2017) expy my dad says no but I'm obviously going to put one since its my vehicle I just cant make up my mind for if I want to do a license plate mount one (22" like I had on my jeep), one behind the grille, or a slim light bar off of the roof racks. Any comments would be appreciated thanks
Big H,
I love your set up. Just looked it up. $340.00 is super cheap compared to Baja Design or Rigid. I was going to get the LGE-CTS bar that goes in the lower grill insert, but was concerned with the cooling since I tow all the time. This looks like a great place to have a good light, easy install and not a huge impact on airflow. Great find. Ordered one up. Thanks.
What makes you think you need 12 gauge wire? I can’t see the light pulling more than a couple of amps, in which case 16 gauge (or even 18/20) is more than plenty. Is it a high ampage light?
Most high end off road light manufacturers recommend 12 gauge wire. Long wire runs, sunset to sunrise operation and a more robust cable. Why not? China lights often have way less. I have not cut the harness off yet, but the fuse wire is 14, it may get smaller. If I remember right the math would be 180w/12v=15a. Not 2a. 14 is fine, but the light is 3 times the cost of an Amazon one and way cheaper compared to a BD or Rigid. The fit to the bumper and grill is what sold me. Hope to use it as a driving light. So it doesn’t need to be a crazy BD light.
Just a reminder that the top part of plastic platform is not level, with a slight downward angel to the front. You might need an angled spacer/washer I didn't realize that until afterward.
Also since it is hollow inside, if you do bother to take off the front bumper, I would suggest put a plastic spacer to fill in between top/bottom layer.
