2013 LED Headlights
medicjack
Changed headlights on the 2013 I just purchased to Beamtech LED. I didn’t realize it had DRL but guess it does. Anyway to turn those off? Looks like the headlights are on at full intensity. Searched and found a few posts saying a dealer might be able to...any other way?
Lights look good at night but I am afraid they may be too bright for oncoming cars. Will test soon.
07navi
Mt.Shasta California
I think that's in the manual.
M
medicjack
Went back and checked the manual. Only talks about when they are supposed to come on but not about turning them off.
bloodhound
Merica
I thought only Canada models had DRL, I've never seen a 2013 U.S. model with them. But if you do have them, I would say your only hope is using Forscan to disable them.
Kjhawkeye1
River Falls, WI
Just curious which Beamtech bulbs you are using and if the headlight is the stock reflector type. I tried some LED bulbs in my stock 2011 housing and they were garbage with less light than the old yellowish stock ones.
M
medicjack
I ordered the adapter today from Amazon to give Forscan a try.
I put in the Beamtech H13 bulb. I am not sure what type of lens this one is called. I assume reflector?
Kjhawkeye1
River Falls, WI
Those are the reflector headlights I have too and the bulbs did so poorly in. Light was scattered with one hot spot on the driver side. Was worried I was going to get us into an accident with them.
Thunderbirdsport
Missouri
These are the ones I ordered, and just received them a few minutes ago. I'll update after I've gotten them in and see what they're like tonight. Stay tuned! :)
Johnathan M
Klingerstown, PA
I turned my DRL off using FORSCAN on my 2011. Easy to do and adapter was cheap on Amazon.
I know this is an old thread, but do you have a source for ForScan code changes for the 2011 Expedition? I have a 2013 Expedition, and it has been very hard to find a source of codes for it. Most of the info out there is for 2015 and newer.
Kjhawkeye1
River Falls, WI
I didn't keep notes and went thru my pictures on this. I think I posted this somewhere on the forum so maybe use the search function.
