Windshield Cowl leak, water in plug wells
Michael Rose
Huntsville Alabama
My 2003 EB recently developed a persistent ingnition mis-fire problem. The cause is water in the plug wells. Seems to be plenty of internet tracks on various Fords with this cowl leak, water in plug wells.
A few internet threads point to diverting water leaks from the windshield cowl.
However, I cannot find any good information on replacing the leaking cowl. There is some information about the cowl design regarding clip locations over the engine that leak water.
Appears there are 2 solutions. Replace the cowl so that the clips locations do not leak. Or improvise a drip-catch under the cowl to divert water off the engine.
I hope there is some knowledge on this forum to help with this problem.
Hamfisted
Ft Lauderdale
Michael Rose
Michael Rose
Huntsville Alabama
The cylinders closest to the firewall, #4, #8.
The cowl, weather strip have no evidence of damage, or loseness. There are 2 clips under the hood, under the weather strip, just about perfectly in line with the plug line, are the culprits. They allow water to drip pass the weather strip.
What cylinders are reporting misfires?
Trainmaster
Old School Member
Rockaway Beach, NY
I don't own that generation truck. If I did, and what you say is true, I'd be looking at silicone and perhaps some half cut hose, sponge weatherstrip and stuff like that. Hard to imagine Ford would.... Maybe not so hard.
mdjeterva
Portsmouth, VA
I had the same problem a couple of weeks ago, we had a torrential downpour, 6" of rain in a day. Next day I started getting a #7 misfire, finally decided to pull the coil and plug in case it was a bad coil or plug. Fortunately I had the compressor out and after I pulled the coil, I blew out the spark plug sleeve and saw clear water get blown out with a little grime. I checked the coil boot and both ends were rusty and a little dry rotted, so I go a new coil boot, applied the dielectric grease and fired it back up. The misfire was gone.
Michael Rose
Michael Rose
Huntsville Alabama
..., so I go a new coil boot, applied the dielectric grease and fired it back up. The misfire was gone.
How are you going to prevent water from getting back in?
How many other plug wells have water in them?
What is the source of your water leak into the plug well(s)?
I have not pulled any C-O-Ps yet. Been taking to my local shade tree mechanic who is very reasonable. But I am not willing to keep paying for this every time it rains. Looking under the hood, not sure how to get to #4, #8 plugs. What has to be moved, removed to get to those plugs? Any special tools needed?
Hamfisted
Ft Lauderdale
mdjeterva
Portsmouth, VA
Replacing the old coil boot has stopped it so far, #7 is right at the drip line for the cowl rubber seal. I checked #3,#4, #7 and #8, #7 was the only one that had any water in it. I cleaned it up and sprayed some Armor All on it and got all of the pine straw debris (the bane of my existence) out of the cowl area and the problem hasn't returned.
#4 and #8 are under the cowl next to the firewall so yours may be a different problem.
JamaicaJoe
Oviedo FL
The windshield squirter system is above the engine block. Any leakage from those hoses could get onto the engine. We all know those engines hate water.
RichardH
TX
I have not seen this for the expedition but on other makes/models of cars.
I've seen boots that 'seal' the well for the spark plug.
Not the best example, but something like this. Do they exist for these expys?
sZxoHoMQycj2QGBTo2knLON6OijW0EpbFR-edjcE8-Ss141PpTDYOBD21cY9D_fLpaGujTHchLGIGv6eiz4iH_t7E5qVX8NWDBE2FU3Mh_-jFygTLDqUKMK6oE9lng7T
Thanks,
Dick
at13
los angeles
I have the same issue; when it rains on my 2002. I changed the cowl but same problem/issue. Help!
at13
los angeles
Have you fixed the issue? I have the same problem with my 2002 XLT. I changed
The cowl; but same issue! Please let me know if you solved the problem!
