window problems
Bilman72
Oklahoma
Ok Guys, On my 2001 the passenger side window will not stay in track as you roll it down. Have tried multiple glues and it keeps happening. Also I have another problem with same window. The door switch on that door doesn't make it go up or down. Have tried 4 different switches, since I have a spare parts vehicle. The weird thing is that the driver side master control will work it just fine. Any suggestions on either problem would be greatly appreciated.
00XTL
North Carolina
Check the wire ing for the door switch. Also is the window falling off track in the door like behind the door panel or up top in the door frame. You could have a broken guide inside the door or the window may be lose.
CaptOchs
Rochester NY
The window staying in track issue sounds like a Window transmission problem. Might need to order a new one. You can order all the parts you want, but I'd take the door cover off and see what's going on before ordering anything.
LAexpy
Los Angeles
This is most likely my problem, as I have this issue on my Driver's window
Trainmaster
Old School Member
Rockaway Beach, NY
I've glued the right side window to its bottom track on my 2000. I used the Ford epoxy sold for the purpose, prepped well and it held forever. I think it cost $30.
Bilsto
Nashville TN
I had that happen on my drivers side. I was told by a bodyshop guy not to bother with a re glue, they never hold. Purchased new window with track assembled. It wasn’t expensive and have not had an issue since.
I started using Loctite marine adhesive sealant for a variety of things at work. I have drains that were improperly assembled (long story) that I seal up with that stuff. It's the most stout silicone I've ever seen. It might work for this, I think it's less than $10 for a small tube at Home Depot. If you try it, clean the surfaces with denatured alcohol first. If it was my truck, this is what I'd try.
LAexpy
Los Angeles
I know someone that works for Safelite Auto Glass, who used some of their adhesive to glue down the window to the track. We prepped the bottom of the window, cleaned out the track, and added adhesive. After 3 days, I tried lowering window and it came off track again! The guide is probably broken
Bilman72
Bilman72
Oklahoma
Thanks guys! As soon as I get a few free hours I will try some of the suggestions.
