Hellwig Rear Sway Bar Not Centered
MHay
Just installed the Hellwig rear sway bar on my ‘20 Max today along with new Moogs end links. I eyeballed the sway bar and got it mostly centered before torquing the U-plates. Took it for a short ride when I was done and now the sway bar is a bit off centered, about an inch or so toward the drivers side. Will this create any issues or is it normal to have some side to side float?
Deadman
Did you have the end links even and straight when you tightened them down?
M
MHay
I think so, but given how the end links rotate/pivot I don’t see how it would matter if they weren’t exactly even when I tightened those bolts? Looking for guidance because maybe I’m making a bad assumption here.
5280tunage
colorado
From the looks of it, it might be okay. Couple thoughts. First, what if you rotate the bottom connector? That is, on your first picture, leave the top as is, but rotate the bottom 180 degrees so it's on the outside of the bar? Just eye balling it that might make it more straight up and down and do both sides. Not sure if you can rotate those, some of them you can, but not sure on the moogs. Maybe only adjustable ones can rotate (actually looking at your pictures i think they are rigid so you won't be able to do that), sorry.
Also, on thing I learned, try to wipe up all excess lubricant, any excess seems to really attract dirt which just gets inside and make them squeek.
wakeboarder
Fort Lauderdale, FL
I wonder if the sway bar in not symmetrical. If you set the sway bar on a flat surface, does it wobble? You would also need to measure the angle and length of the outer bends.
5280tunage
colorado
On mine, as I used to do with my Jeeps all the time, I simply didn't tighten down the chassis mounts, left them pretty loose, and drove up and down my driveway a few times. Going over the curb will help the bar naturally settle in place on its own, assuming it's symmetrical. Then I cranked the chassis mounts down. My front one shifted probably 3/4". The rear not so much. Of course that meant a lot of the grease was exposed now, but it was still centered.
M
MHay
The links aren’t adjustable, and thanks for the tip about the grease. I’ll clean up the excess once I’m finished messing with the alignment.
I had the new bar lying flat next to the old after I removed the old one and I don’t recall noticing any wobble or anything that didn’t match the length/curvature of the old bar. However, I didn’t measure so there’s a chance it is off a bit.
I think I’ll try this first as I won’t need to undo the whole bar. :banghead:
tskrypek
US
Where did you get your sway bar? How long did it take to get it after ordering?
Sent from my VS988 using Tapatalk
M
MHay
I ordered it from autoaccessoriesgarage.com on 10/15 and it arrived 12/15.
tskrypek
US
Your lucky it came so soon, they have been quoting 3 months. They have to make to order.
Thanks
WALoeIII
I ordered front and rear directly from Hellwig 12/8/20 and they arrived 2/4/21, boxes had a lot of tape on them, seems they've learned a bunch are poking out.
My rear also floats a little, even with 50 ft-lb of tension on the frame u-bolts I can still slide it side to side if I try hard. I wouldn't worry about it, ultimately its going to slide back and forth a little if you twist up the truck.
Nice improvement to handling, truck is much flatter when cornering.
Deadman
I ordered mine from Hellwig directly, they need to make it to order, so no need to involve another vendor....
Nate2020KR
Athens, GA
I was going to order from them directly, but they charge $50 special order per bar. I called and they said they didn't sell directly to the public and would have to be purchased through a dealer. But their sir will let you order from them. Who knows?
Deadman
Ya know, I noticed that their website has changed in the last year or so. I'm wondering if they didn't change their policy on that. They gave me a 10% off code that I used and ordered it directly thru their website when I ordered. I got the 10% off because they ****** me around for monthssssss while they hid in their basements form the Plandemic.
Squark
NC
I installed my rear bar this weekend and had the same issue. The bar was centered when I tightened it down but it shifted an inch or so while driving. The factory bar has ridges that keep it from moving, while the Hellwig one is smooth. I'm not going to worry about it since others are seeing the same thing.
5280tunage
colorado
And naturally it should find center on it's own anyways. Which may not be center chassis wise but things like weight distribution can affect them. They are designed to "float" a little.
