How fast does your Ford Pass start your vehicle or unlock/lock doors?
How quick is your FordPass
  • 1 second
    Votes: 0 0.0%
  • 2-3 seconds
    Votes: 3 12.5%
  • 4-5 seconds
    Votes: 2 8.3%
  • 6-7 seconds
    Votes: 1 4.2%
  • 8-10 seconds
    Votes: 11 45.8%
  • 11 or more seconds
    Votes: 6 25.0%
  • Don't know
    Votes: 0 0.0%
  • My butler does it
    Votes: 1 4.2%
  • Total voters
    24
armoredsaint
I think they're using a version of this in their new electric cars to unlock/lock, but if it takes longer than 3 seconds it becomes a PITA if you're in the rain or you're about to get robbed:)
Mine from timing it several times is about 7-14 seconds from starting to lock and unlocking
Lou Hamilton
I’ve never used it to unlock them.
I’ve used it lock them if I can’t remember if I locked them before bed.
I usually use it to warm up the car before getting in it.
10sne1
Mine works about 50% of the time to start car? It just seems to time out and give up, about half the time? not used door locks yet.
Jimmer
Eau Claire, WI
Has anyone tried to remote start or un/lock from the FordPass app on their apple watch?
I've tried about a dozen times and as soon as the wheel starts spinning it pops up an icon to "Refresh" and doesnt do anything.
One of the times I tried about 6 times in a row from my watch and ended up with an error message on the phone app that it wouldnt attempt to start after so many failed attempts. So it seems like some connection may have been happening but the "Refresh" popping up wouldnt allow it to fully execute.
I checked in the app settings for the watch but didnt see anything to toggle that would help.
byathread
Pennsylvania
I only use the app (mine also takes a bit, probably 15 seconds or so for start or lock/unlock) if I want to start and keep the truck running for more than 10 mins...
99% of the time I use the fob for remote start. Fob in pocket to lock/unlock doors and keypad if I'm walking away from it and leave it running with key inside so I don't get the double honk...
[emoji106]
Fozzy
Riverton
I have found if the Ford Pass app is running in the background the response time is pretty good. Including the Apple Watch app. If it is closed out it takes forever to say it started. The watch app seems to go to refresh after it sends the command. I have been right next to it and the Expy would start or unlock after pushing the watch app button and the watch would say refresh. If I started it from the watch I would have to push the refresh button then push the unlock button. And like mentioned before the app needs to be running in the background on the phone.
Jimmer
Eau Claire, WI
Thanks, Fozzy. I'll give that a shot with the app running in the background on my phone and try to be more patient instead of hitting refresh right away when it pops up!
Fozzy
Riverton
Best thing about using the app is you can extend the run time 10 more minutes if your windshield is super icy.
Mlarv
Eastern TN
You realize that the App is going from your cell phone across the cell network to a internet connection. That internet connection has to find the Ford servers and see if you are authorized to do what you want to do. Then send a code back across the internet to a cell tower your vehicle is connected to, then into the vehicle so the code can be read and then acted upon.
So it may take 10 seconds to over a minute.
I use the App to start my truck at the airport parking lot when I hit baggage claim if it has been snowing and I want a warm truck.
I have used it once when my wife needed to get something out of it while not was parked in a mall parking lot.
Other then that I just walk up hit the button on the fob and the doors unlock with in a second.
Mlarv
Eastern TN
They are using another technology called NFC to control the door locks etc. It is not cellular like the APP is. Sort of like paying with Apple Pay but you open your doors and start your car or truck.
Fozzy
Riverton
My wife’s 2020 Aviator has the “Phone as Key” feature. I imagine it will work it’s way to the Expy and trucks in a few years. My wife didn’t like it. She keeps her keys in a zipped pocket in her purse. If she forgets her purse will gabbing on the phone the car will not unlock. So she knows she left it somewhere.
Fozzy
Riverton
I thought you can do it twice then it said you have reached the limit.
Fozzy
Riverton
I just let it run down to 2 minutes and added another 10 minutes.
Moderator
Depends on the settings in side the vehicle. If your start cycle is set to 10 minutes, each press gets you another 10. If your cycle is 15, each press gets you 15 more. No matter the length you have the cycle set to your maximum runtime is only 30 minutes. So set to 10 you can extend 2 times, set to 15, only 1 time. Hope that clarifies it a bit.
Fozzy if you set your runtime in the remote start settings in the menu to 15, you would match the others.
Also, if your runtime is set to 5 minutes, you can extend 5 times...still totaling 30.
No members online now.
lanzarote wayne
