Update all versions of Ford Sync 3 to the latest Sync 3.4
Moderator
Thanks Loki.... next question, which version do I want? We both have 3.0 SYNC I am build 18093 and she is 18025, both with Nav. Just stable upgrade that is turnkey! (Especially for her, any quirks and I'll never hear the end of it!)
The newest 3.4.20282 is stable. Use it. Download the install builder from CyanLabs and follow the instructions. You can use the same installs on both.
Anthony DeVor
No just in general I haven’t attempted it yet due to the fact that I could brick my apim
Moderator
You won’t. The majority(95%) of the people you hear of bricking it, attempted the actual firmware update early on(that has even gotten better). That firmware gains the original 3.0.XXXXX units the Calm screen and Radio icons. That is not worth the risk...
NewExpyDriver
Hmmm, couple weeks ago, I tried new update to 20282, after previous 2 successful ones. Used new uploader and sync system would not take the update. Asked for advise here and got only crickets. Took her in to dealer and they had her for several days only to tell me they could not get the system to update either. They even said the parts were not right one for my vehicle. Longer story short, a new module was ordered... but is on back order....until early-mid february. System still works fine on 3.4 19200. We shall see what happens when new parts come in.
5280tunage
colorado
What is up with parts? Seriously, folks on here waiting 2-3 months for struts, I've been waiting 5 weeks for the front camera washer fluid assembly since it barfed all over the dealers floor... I know I know, Covid this and that. If anything, this proves how fragile their supply chains are.
Just to echo what Loki is saying, I've probably done about 12-15 of these updates now on mine with zero issues. Frankly, the only time I had any issue was with crappy thumbdrives.
Hey Loki, I'm assuming the ports in the vehicle are still some version of USB2 right? i.e. USB 2.1? Seems that if they were 3 this stuff would likely go a lot faster. I pretty only use USB3 sticks anymore.
Also, I definitely have not tried the firmware, just doesn't seem worth it. Everything else works fine.
Gumby
Beaumont, Alberta
When they replaced my rear shocks, parts were backordered. They had to get them sent from another dealer about 2 hrs away.
As for the updates. I've done probably 4-5 so far including the reformat from 3.0 to 3.4 with the map pack and no issues - ever.
Anerbe
Mi
part shortages are still common, especially service parts, as most vehicle production is currently bottlenecked with supplier parts from the covid shutdown. vehicle production parts will get priority over service parts for the majority of the suppliers.
5280tunage
colorado
That's funny. If that is truly the case, it's like saying - hey current owners, thanks for buying our product but we care far less about you right now, future buyers have priority... Love it. Not to mention that legally, in some cases that would literally lead to safety issues for current owners, that should be regulated by NHTSA...
Anthony DeVor
Im getting ready to do the update, what version would you suggest? I currently have version 3.0 Build 20204, Gracenote Version 1.1.1.1149, Nav Map Version 1.15 and have no issues but would like the redesign. I don't have the speed issue in Waze. What would you all recommend?
Moderator
Do it...
Moderator
The USB chipsets are technically 3.0 because they have to be to be Apple CarPlay certified, but I think the bus on the APIM is not. I agree on the speed. Also, some of the drives early on I had the best luck with were good USB 2.0 drives. They were only slightly slower than the 3.0 drives I use now...
Yeah, stay away from the Firmware unless you are brave and fully understand hat you are getting into.
Anthony DeVor
I updated my Sync 3 (3.0) to 3.3 first to make sure it would work then to 3.4 and everything went smoothly. The only issue I have found is it has now tripled everything in the APIM in Forscan.
Anthony DeVor
Also has anyone messed with the themes and figured out which ones work properly? Because from the test settings on the radio itself the first 2 I tried the resolution is way off.
Moderator
Did you use the CyanLabs install, and after the update did you reboot 2 times?
Moderator
Also, just for clarity, please nobody else go to 3.3 instead of straight to 3.4. There is very little difference between going from 3.0 - 3.4 vs 3.0 - 3.3. 3.3 has some issues...and could cause other problems.
Moderator
Most Themes will work other than the 10.1 ones. Those are for the vertical Explorer and the horizontal Lincoln’s.
No members online now.
Landsbutter
