Update all versions of Ford Sync 3 to the latest Sync 3.4
Rob18
Louisiana
Just updated Sync 3.0 to 3.4 now my outside temperature display is stuck at 60 degrees. Any ideas? Could it be caused by something other than the update. I am not sure if it was working correctly right before the update but was working a few days ago.
MxRacer965
Hudsonville, MI
have you rebooted it a couple times? If you rebooted it a couple times did you try a reset?
mcb345
Nashville, TN
Hey all you 3.4 folks. Can anyone jot down some of the larger benefits of upgrading from 3.0 to 3.4? I started reading through the first 10 pages of the thread and didn’t reall gather many answers.
Can you see carplay directions on the drivers display? Does the speed limit pop up next to the digital speedometer? Really are there any meaningful features added or is it mainly just an updated look / UI?
Also I have a CPO warranty and then Ford extended warranty, will upgrading void the warranty for any and all aspects relating to the sync system and overall interior settings and sound system?
Rob18
Louisiana
As far as the external temperature issue. It was my bad I didn't realize that the vehicle needs to be moving for the temp to change.
TheAngryOgre
Reisterstown, MD
MCB345-
Running 3.4 in my new 2021 XLT. Connect the iPhone to the USB jack (either one) and full CarPlay functionality displays. I run Waze for nav and it works perfectly.
mcb345
Nashville, TN
MCB345-
hey, just to confirm you’re saying CarPlay displays on the screen on the driver’s gauge panel above the steering column correct?
TheAngryOgre
Reisterstown, MD
My apologies...did not read your question closely enough. Nothing on driver display, only on the head unit for 3.4. Sorry about that.
5280tunage
colorado
Anyone notice that with this version (20351), Android Auto no longer has an exit button to exit back to the sync3 menus while the phone is plugged?
5280tunage
colorado
Ah figured it out. Apparently in one of the recent updates, the "Exit" button with the ford logo was relabeled to now say "Sync", while still using the Ford logo. Not sure why you would relabel that, to me exit is logical. I want to exit AA if I'm pressing that button.
8131full
Las Vegas
Any way to turn off the Navigation Chime while using the map? It dings incessantly now. Prev ver i was able to turn it off.
mpc11
MI
Did either of you also update the nav to the 2020 maps?
Jon F
Dublin, Oh
Just updated to the latest 3.4 on my 2019. The siriusxm channel icons are present but the album artwork is missing. Is this normal or did the gracenote information not copy correctly? Apologies but I looked and could not find the answer before posting this. Thank you!
LokiWolf
Moderator
Richmond VA
Yeah, 2 20 is available now. If you have a 2020+ you can’t do it currently unless you are will to use a method still in development. If you have a 2019 or earlier you have do downgrade then load, but the CyanLabs installer does that for you if you input your current version correctly.
