pgaylock
I need to travel @ 325 miles & tow it back with a tow truck that I am purchasing.
Yes you can but you will get warning lights.
Warning lights? Where did this come from?Why will he get warning lights?
Warning lights? Where did this come from? Is your truck 3 or 4 wheel drive?
Because the computer will know the rear shaft is off.Why will he get warning lights?
No he won’t. Take it off it’s fine
How? How will it "know"?
Hold on..I want to see his logic on this.
Have you read the thread title lately?From 4 wheel drive guide;
Can you drive a 4WD truck without a front or rear drive shaft? Yes, this is possible if you drive a traditional 4WD with a lockable center differential. Remove the damaged drive shaft and lock the center differential. This will allow the transfer box to transfer power to the front or rear drive shaft. You will be able to safely drive the vehicle in front wheel drive or rear wheel drive mode. A few warning lamps from the ETC system might start flashing but don’t panic.
From FTE;
Running no rear driveshaft - Ford Truck Enthusiasts Forums (ford-trucks.com)
From FTE;
Yea I screwed that up. I did that before, I think it was back in 1990.Have you read the thread title lately?
Yea right, read all your 35+ again...........lolha·rass
/həˈras,ˈherəs/
verb
verb: harass; 3rd person present: harasses; past tense: harassed; past participle: harassed; gerund or present participle: harassing
subject to aggressive pressure or intimidation.
"being harassed at work can leave you feeling confused and helpless"
Correcting your wrong info online isn't harassment. If anything, you're the one harassing people, posting misleading or incorrect info, calling people names, being derisive, and being vague in your posts.
