Lowering and Shocks
No_Expedition
Oklahoma
I have a 2010 expedition limited. I would like to lower it but I am having trouble finding a lowering kit.
Do you all have any suggestions along with what shocks to go with it?
Adieu
SoCal
That's cause it's a truck, you're supposed to RAISE it
The station wagon is called a Ford Flex
Newport News, VA
They don't make readily available kits for us... they did for 1st gen but nothing after that... you'd have to get custom made
Sent from my SM-G965U1 using Tapatalk
Newport News, VA
Talk to coilsprings.com and the can custom springs to lower the truck...I lowered 2.5 inches all around... loved the look... swapped out cuz I added sound system needed springs to hold the weight and good another set from them but raised truck back to ride height... thinking of lifting it
Highjaxx
Kyle, TX
You will need to contact Air-Bag-It directly. They didn’t have the lowering kits for our trucks online. I called and spoke with them to order mine. Was about $700 at the time for all 4 struts/springs.
They have 2” and 3” options.
Ricanracer140
Look on eBay. I purchased lowering struts. Basically replacement struts with modified spring perch lower on the strut body. I’m running the 3 inch drop. When new they were great but since they use a Monroe type replacement fronts are a bit weak now. They’re advertised as lifetime warranty so I’m in the process of replacing the front hopefully with a better strut.
Kevin08
Illinois
E0215452-0E27-48D2-A95A-4D455BB76201.jpeg Any new information for someone like me wanting to lower an 08 Expedition 2wd? I’ve wanted an Expedition ever since Ford came out with the 1st Gen.
But because of my disability and severe pain, I was looking at Freestyle or even (gasp) a minivan. I found this 08 King Ranch with all the accessories I needed to make life functional like power lift gate, power fold, heated seats, smooth ride, and can transport the mobility cycle. I couldn’t resist getting it.
It’s a little high and painful to get up into and out of the front seats, plus the load floor is a little high too. A stiff ride is painful for me, so I’m leaning toward drop spindles instead of lowering springs/struts. I know nothing about lowering an Expedition independent rear suspension though. All I can find searching the internet is leaf spring shackles or the shorter coil overs. The previous owner has swapped out the rear air shocks for coils. He said he didn’t like the air leveling rear, but my guess is the system leaked and this was the cheaper permanent fix. My idea is to lower and delete running boards. The passenger side board is busted on the outer edge anyway plus I’ve had other vehicles with running boards and if I try to weight bare on them I usually get my feet tangled up.
Not slammed, just lowered enough I feel like I’m in control of the exit instead of a sketchy free fall, lol.
Dream scenario would be air ride on remote key fob or lowers when ignition is turned off for entry/exit and closer to stock ride height going down the road. But not likely affordable for me. So I’m happy with an easier entry/exit-comfortable ride compromise.
Recommendations?
Kevin08
Illinois
No one has aftermarket adjustable air suspension on all four corners?
Or advice on 3-5” lowering suspension components?
08 2WD stock 18” rims.
Aspen03
Indianapolis
I think you'll have a bit of a time finding someone here that has done an aggressive drop. Most people want to lift these things, not lower them, its counter intuitive to most large suv platforms. If your goal is a 5" drop I'm guessing you're going the air bag route and it will be custom and pricey.
I understand why you want to do it makes perfect sense for your use case but you're in the .01% that's trying to do this. Perhaps reach out to local shop for advice. They may not have an ideal solution that's affordable but could give you an idea what is possible based on the available budget.
omn williams
st auguatine, fl
I just sold a 2007 that I dropped 2 in using offset bracket on front struts and lowing springs on rear struts. Needed more drop to allow for ease of entry. Be careful using dropped rear springs, as your cargo carrying capacity goes away.
Newport News, VA
That's why I suggest custom coils
Sent from my SM-G981U using Tapatalk
Kevin08
Illinois
Transmission swap is finished. Short test drive and as I expected, the rear coil struts the previous owner installed give a very harsh ride. The front glides over bumps then the rear hits very hard like a 1 ton truck. I’ll have to do something soon.
Kevin08
Illinois
I cut one coil off each spring on my 04 and it turned out amazing dropped it about 3” all the way around
I wish my 08 didn’t have tapered coils or I’d do this to it. That looks really good.
I’ll have to look at mine again, but I though the last coil gets smaller for the perch?
Expy4lyf
San Diego
I'm not sure if this thread is still going on but here is some info for 2007-2013 expeditions. And for 2003-2006 expedition/ navigator a company called maxpeeding rod makes coilovers for this year.
