DIY Oil Change
DCS_express
Thanks everyone for the information.
Yeah . . . it's been a long time since I owned an "American" car so I assumed everything would be standard. The 78 Bronco I had 20 years ago I don't think was metric, but it also wasn't completely stock either.
scottdm
Western PA
So will the Fumoto valve screw in without any issues even though the OEM drain plug is a plastic one?
The Fumoto valve only works if you have the aluminum oil pan. You must have an early production 2018 model if you still have the plastic oil pan and yellow plastic oil drain plug.
Luis Monjaras
Brambleton, VA
I have a 2019 Model. I was just looking at a video on You Tube for Oil change instructions. The person changing the oil had a 2018. I figured that all the 4th Gen Expedition came with this. I am glad that they don't if that is the case because i order the Fumoto part before i looked at the video on YT. LOL.
scottdm
Western PA
You have the aluminum oil pan if you have a 2019 model, so the Fumoto will work. You may also want to evaluate Stahlbus and Valvomax drain valves to see what you prefer. I originally had a Fumoto and switched to Stahlbus since the Fumoto doesn't have a threaded cap to protect the drain port between oil changes.
Luis Monjaras
Brambleton, VA
Thanks man!!
rd618
new york
Did the thread diameter and pitch change for 2022? Valvomax shows M14-1.50?
