Scott Carden
Full Access Member
I don’t care for the sumo springs as the can cause your springs to break on the ends. I am using bilstien 5100 adjusted all the way up and fords latest spring revision. Also a hellwig rear sway bar. The setup works fine towing or not. The downside to expy suspension being independent is that a helper spring or overload air setup won’t work. There are other options but get your wallet out as they are not cheap.
