I went from 22s down to 18s went with methods and put a 275/70/18 cooper stt pro tire on it since I sometimes offroad towing my SXS or camping. Speedo is off by like 2-3 mph since its about an inch taller tire than the stock but not a big deal.
Factory rim and tire sizes here: https://www.wheel-size.com/size/ford/expedition/2019/
To try non-factory sizes, and see the effect on your speedo, look here, click Alternative Sizes, click on More Wheel Sizes and choose the rim diamter you're interested in: https://tiresize.com/tires/Ford/Expedition/2019/Platinum
having seen the wheels up close, which are nice, it seems the spokes protrude out from the rim, so really need a wide tire like the OEM BF Goodrich tires.
What tires did you put on the raptor wheels?
Nitto Ridge Grappler 33x12.5R17.
Had them on my 2005 and swapped them over almost immediately.
They are probably the most aggressive All Terrain available right now. Noise level is a little more than an AT but not as loud as an MT.
So in the pic, the shop just finished installing the ReadyLift and tried to align it. With that tire wheel combo, there no lip for the wheel alignment attachment to grab onto. So I had to bring the original wheel down to the shop and they put them on for the alignment.
Hi, I live in New England and want to ditch my 22 inch Platinum rims for a tire with more profile and more of an all season set up. I also off road on a beach and will be airing down. I understand you can break the bead on low profile tires when airing down with low sidewalls. My question is, should I go to 18” rims or 20”? And are there ramifications for the speedometer or other electronics? I have a 2019 Platinum Expedition. Also happy to take tire recommendations. Thanks.
T
Any clearance issues with that 17” Raptor wheel? Is it a bead lock wheel?
Also , with the new setup and ReadyLift, did you need to trim any wheel well liner? Or step boards?
I have the ReadyLift with OEM Raptor takeoffs (31570R17 BFG Load Range C) on my 2020 FX4. They are beadlock ready but I’m not running them with the beadlocks engaged. Had to tuck the front wheel well material up a little bit, but very easy. No rubbing whatsoever!
Excellent.
I’m finally giving my Platinum a mild off-road makeover.
Already have some parts in the garage. Rear Helwig sway bar (still waiting on delivery of the front sway bar). Moog end links. ReadyLift 3/2.
Ordering skid plates this week. And onboard air.
I originally was going with 18” wheels, but a local guy is selling his 17” Raptor wheels that were new take-offs. I would get the same exact size tire that you are running: 315/70R/17. That is a 34.4” tire, so good to know you aren’t having any major interference issues.
Your BFG’s are load range C. How do they ride? I was looking at the BFG KO2 which are load range D, but I don’t want a real harsh ride. Part of the benefit of getting rid of my ridiculous 22” rims, is to get more sidewall for a better ride.
