I went from 22s down to 18s went with methods and put a 275/70/18 cooper stt pro tire on it since I sometimes offroad towing my SXS or camping. Speedo is off by like 2-3 mph since its about an inch taller tire than the stock but not a big deal.
Factory rim and tire sizes here: https://www.wheel-size.com/size/ford/expedition/2019/
To try non-factory sizes, and see the effect on your speedo, look here, click Alternative Sizes, click on More Wheel Sizes and choose the rim diamter you're interested in: https://tiresize.com/tires/Ford/Expedition/2019/Platinum
having seen the wheels up close, which are nice, it seems the spokes protrude out from the rim, so really need a wide tire like the OEM BF Goodrich tires.
What tires did you put on the raptor wheels?
Nitto Ridge Grappler 33x12.5R17.
Had them on my 2005 and swapped them over almost immediately.
They are probably the most aggressive All Terrain available right now. Noise level is a little more than an AT but not as loud as an MT.
So in the pic, the shop just finished installing the ReadyLift and tried to align it. With that tire wheel combo, there no lip for the wheel alignment attachment to grab onto. So I had to bring the original wheel down to the shop and they put them on for the alignment.
Hi, I live in New England and want to ditch my 22 inch Platinum rims for a tire with more profile and more of an all season set up. I also off road on a beach and will be airing down. I understand you can break the bead on low profile tires when airing down with low sidewalls. My question is, should I go to 18” rims or 20”? And are there ramifications for the speedometer or other electronics? I have a 2019 Platinum Expedition. Also happy to take tire recommendations. Thanks.
T
