Alignment and dealer(s)
plumcolr
freehold nj
My '17 is showing abnormal tire wear, outer shoulder LH front wearing rapidly. So just for grins I went to a dealer and asked how much for alignment service, Oh, about 150 I was told (most places around here get 100+tax for a 4 wheel alignment). OK, I thought, too much. I told the guy it didn't have camber bolts. Oh, that'll be an extra 300 to install bolts.
I'm sure that would have come to their attention after it was on the rack and bolts loosened. %&@$ crooks!
Gonna put camber bolts in my own self and take it to the guy down the street. A decent set of 4 camber bolts and brackets is about a hundred bucks.
ManUpOrShutUp
I took mine to Firestone for a 4-wheel lifetime alignment during 1 of their promos several years ago ($200 or so). I waited for a few hours and when the manager (also turned out to be the owner of the franchise) told me I was ready to go I paid the bill. After I paid the bill, he pulls out a printout and says: "By the way, we only did a 2-wheel alignment because you have factory shims. For another $250 we can remove the shims and do the other 2 wheels." Uh, no. I paid you for a 4-wheel alignment. The time to tell me you couldn't do it for that price was before you started the job, not after I waited 3 hours and paid in full. He essentially told me to stuff it when I argued, so I filed a credit card dispute. I provided proof that I paid for a 4-wheel alignment and only received a 2-wheel alignment. Bank found in my favor very quickly and he got zero.
ManUpOrShutUp
How'd those tires wear after that? I hope he didn't get the last laugh. Franchise shops around here are completely incapable of doing anything right except collecting your money.
The vehicle pulled to the right for a bit tbh, but I was driving on a lot of crappy roads at the time so it eventually self-aligned. :p I can't really answer the tire question accurately. Two of them wore pretty evenly and got me over 60k. The other two I blew out on national park lands and their 1990s-Sarajevo-like roads.
dcsang
Alignments are hit or miss just about everywhere I've been. Either very few techs know how to perform a proper 4-wheel alignment or most just don't put much effort into it. I once purchased a Sears Automotive lifetime alignment and revisited to the same location numerous times for adjustments before finding a location in another borough with a knowledgeable tech who listened to my concerns got it right on his first attempt.
Since Firestone was mentioned I'll just add that my only experience with them was through my brother. I changed his brakes and rotors a month before he took his vehicle to the only location in town for an alignment, thinking it would be better than a random garage. He called me at work to say the mechanic was changing his brakes and rotors because they were unsafe and badly worn, at the cost of $500+. I flew down there in record time to speak with these people, who had allegedly completed the job. I won't bother with the details but the result was payment for an alignment and nothing more after they failed to produce the parts they allegedly removed.
Rant over. This was several years ago and I still get tense thinking about it.
plumcolr
plumcolr
freehold nj
There are a couple of usually good shops around here, none of them franchise.
I say usually because auto mechanics (non-dealer) sort of float in and out, sorta like Cher singing "Gypsies, tramps and thieves". It's up to the proprietor.
07navi
Mt.Shasta California
I rarely take anything to a shop (unless I have to) but they always try to rip me off and I always end up with an argument or a near fight. They always assume that I know nothing which is why I brought it there but it's really for other reasons like no room or time etc.
I’ve never been able to get my EL properly aligned by anyone. Front tread wears on outsides slightly faster.
mjp2
Howell, NJ
Are you running the factory lower control arm bolts? I'm in the process of rebuilding my truck and was surprised to see the front LCAs didn't have concentrics. Due to rust I had to cut off the arms and factory bolts anyway so I replaced with an alignment kit. Curious to see how it aligns once everything is back together.
With that kit a shop should be able to push the LCAs out a bit to address the outside tire wear.
07navi
Isn't it the top arm that controls the camber though?
Retiredusps
N.J.
Goodyear is no better. Picked up a 2002 f-150 serviced only by goodyear. They never lubed the drag link end on the frame rail. Guy I bought it off had it pull it completly off the frame rail frame plated both sides truck still on the road!!!!!
Old Gearhead
Cadiz, KY
I would never go to Firestone again for any service. Here in KY, Hopkinsville Firestone is worthless. Poor service, untrained technicians and long waits. I do go to Leon Riley Ford in Benton KY with VERY good results for all of my repairs. I do agree with many of the reviewers, unfortunately many of today's alignment shops are hit or miss.
Brons2
Austin, TX
Interesting that a number of posters mention outside tire wear on their vehicles. When I got mine it had noticeably worn the insides of the tires. I replaced the tires a few months back, but dreading the alignment job that I probably should have done to avoid my new tires suffering the same fate.
Fastcar
Army
FL
Firestone has worked years and screwed many people so they deserve the reputation they have. POS
rjdelp7
2000 XLT
NY
If the alignment was done with a worn or bad ball joint or tierod, it will never be right. 90% of alignments, the toe in/out adjustment is the only thing done. Always make sure the shop gives you the print out, showing everything 'in the green'. AAA car care, gave me the excuse, the printer ran out of ink. Guess what, I wound up going back because it was still off. The lazy tech tried to BS me and say my steering box had 'free play'. Then he used the old go to 'it may be a tire pull'. The second alignment was better. There is a guy on youtube, that shows using a tape measure and string pulled tight, to line back wheels, with the front. The string takes the place of the laser. I tried it, adjusting the tierod using measurements off the string. I adjusted the camber with a level and the rim. It drove perfect. In fact, I paid for alignment, just to see how close I got it. The tech said it was all in spec.
07navi
I have been aligning my wheels with strings and bubble levels for about 50 years with NO problems, I can't remember the last time I had a shop do it. OK everybody squawk NOW!
Brons2
Austin, TX
What are the tools and procedures needed for this?
