Cthunndr
Greetings. I have a 2007 EL 4wd. I recently had the left front wheel bearing go bad. I went to autozone and bought a new one. I installed it and after taking it for a spin the noise occurred with the new hub. I took the new hub off and went back to autozone at which point they exchanged it for another one. I put the second new one in and it was quiet for about 10 min and then the noise again. I kept it for while because I didn’t have time to swap it out. When I did have time, I went to NAPA and got a third one and installed it and had the same issue. I am at loss as to why I have 3 hubs that were bad from the start. Is that even possible?
Each hub had the up/down play once the noise started. There was no movement from left to right. Btw, I checked the play by having the wheel off the ground. The only other thing to mention is that during the first install I snapped the stud on the axle when putting everything back together and had to go to autozone to get a new axle during that time. The shaft appeared to be a perfect fit...the only difference is that the stud on the end of it was slightly smaller than the oem one
