If you can answer either of these, you are a genious!
rob4092xx
Phoenix, AZ
Two quwestions:
1) My rearview mirror keeps shaking when I drive. It is making me nuts!!! How do I tighten up the rearview mirrior on my 2010 Expedition? I couldn't find a hex screw like on all other mirrors.
2) I need to re-paint the two tannish colored pieces located on the top side of the gear shifter. These are the two trim pieces that attach to the top of the gear shifter.
Only an expert can answer these!!!
Stoned06
Milwaukee
No expert here, but the first should be taken care of by the warranty if you're within miles. If not, then it's the swivel for the mirror that is broken or too loose. No adjustment, just replacement AFAIK.
For the second problem you have to remove the pieces, sand, prime with the proper plastic adhesion primer, then topcoat it with the matching interior paint. However, if the scratch isn't due to your doing and it's a defective piece, try getting it covered under warranty. I know BMW has had a lot of issues in the past few years with peeling paint on plastic pieces and it gets covered under warranty.
R
rob4092xx
Phoenix, AZ
Thanks so much for responding Stone!
My question on the gear shift handle is how do I remove the two plastic pieces so I can paint them???
corlon
midwest
side note:
try calling a dealer for a replacement cover. i bet its around 30.00 bucks for the top and bottom together. just make sure to have your vin number handy for them. could cost less then the parts and your time needed to paint the old one:?
R
rob4092xx
Phoenix, AZ
Can anyone explain how to remove these pieces? I tried, and for the life of me cannot figure it out!
side note:
R
rob4092xx
Phoenix, AZ
I cannot for the life of me figure out how to get those two plastic pieces off the gearshift knob! Arggg!
Stoned06
Milwaukee
Sorry, can't help you figure out how to remove them as I have a 2006. You might have to remove the entire center console, or the bucket from the bin to see how everything is attached. Possibly the gear knob has to be removed to slide the pieces over it? If you can take a few pics and post them and we might be ale to determine how it's put together.
As reference, the 2006 has a front bin/tray that has 2 bolts holding it in under the rubber mat. The top part of the console just pulls straight off by popping the clips out. And the bucket can be removed after removing the console lid. I'm sure the 2010 utilizes similar technology for the console trim pieces, just not sure which.
