Sand driving - manual says 'avoid reducing tire pressures'
bobvance2005
MA
Everyone who routinely drives in deep sand says it's critical to reduce tire pressures significantly to reliably not get stuck. But the manual on my 2021 FX4 says "When driving over sand...avoid reducing the tire pressures but shift to a lower gear and drive steadily through the terrain".
Why is Ford, apparently, against reducing tire pressures for sand driving?
Fastcar
Army
FL
Because most will air down too much and lose the bead. Without bead lockers I wouldn't less than 17 pounds with stock tires and then gently drive out without making sharp turns.
B
bobvance2005
MA
Yeah, I get that, but was also wondering if Ford is maybe worried about overheating the elsd (I've seen a few threads on that happening) - not sure if low tire pressures would even cause more stress on the diff, though...just a thought
p38fln
No, if Ford was worried about that the manual would say never to do it, not to avoid it.
scottdm
Western PA
Depends on how fine/dry the sand is. When I drive in the Outer Banks of North Carolina I typically air down to 20 psi or so. The sand is very fine and there are deep ruts. If you're driving closer to the surf on hard packed wet sand, you may be fine without airing down.
Fastcar
Army
FL
I wouldn't think that would be an issue.
I would suspect there is a safety-related reason.
Have you driven on sand and followed the advice in the owner’s manual?
Squark
NC
The first time I drove on the Outer Banks I followed the manual and did not air down. I drove into soft sand and quickly got stuck. A local dug me out, had me air down to 15psi, and I never got stuck again. I agree with scottdm above. If it's hard-packed wet sand, it's probably fine. But deep, fine sand requires low tire pressure.
B
bobvance2005
MA
OBX is where I will be doing some sand driving (haven't yet). Been watching some videos, and yeah, everyone says 15-20psi, if not lower.
B
bobvance2005
MA
Yeah... The manual seems like bad advice. Or at least, it should specify "packed sand" or whatever.
Trainmaster
Old School Member
Rockaway Beach, NY
I've spent many years driving on Long Island beaches, which are generally rutted fine sand. It's pretty hard to get stuck with 12 - 20 lbs of air in your tires. If you don't reduce the pressure in fine sand, you WILL get stuck. I promise. You don't think people buy $300 compressors because they like playing with their tires in the dark, do you?
Tmg115
Dfw
Ford will never say to air down your tires due to safety. Most people have no clue what they are doing off road. Most people will pop the bead or not air their tires back up when they are done. That's why Ford will never say lower your tire pressure. They don't want another Firestone issue again.
Fastcar
Army
FL
Its probably because most don't have a compressor on hand, so when they get back on the road, they drive with them at low pressure at highway speeds......
I remember before you could go on the sand at a couple of beach's on Cape Cod you had to have a air tank, shovel, jack and a hunk of 2X12 to go under the jack. They checked for all of it before you entered.
NukeLife
Charlotte
Guaranteed it’s because people try driving back to a gas station to air them back up.
VIAIR portable compressor. Best $200 I’ve spent on my truck.
But make sure you grab it by that handle . That sucker gets HOT
Mack444
CA
Sorry to revive an old one. Wondering about sand driving since we are headed to Oregon next week where I can go out on the beach. It will be the first time in the Timberline, last time was in my Excursion. If I air down to 20 to get through some of the soft stuff, how long on the road is ok to drive and below what speed? Nearest gas station is nearly 10 miles from the beach spot. Thanks for advice on this.
No members online now.
Landsbutter
