2019 platinum 4x4 - performance tune recommendation
mightyexpy
chicago
been doing some searching, and tried calling 5-star, without any luck.
I got a SCT BDX tuner and currently leaning towards the 5star tunes.
2019 platinum, 4x4, tow package.
Only mod will be the S&B intake kit.
Question is:
Anyone have experience with either the e30 or e50 tunes?
I plan on ordering:
- 93 daily/tow
- 93 performance
- maybe one of the e30 or e50
Looks like so far driveability reviews are good from what I’m reading.
Any issues I need to be concerned about?
Thank you in advance… been trying to keep this truck stock, but can’t help myself.
5280tunage
colorado
There are lots of things to be concerned about, and I actually find myself somewhat concerned about running tunes. It is so easy for dealers and techs to figure out that a vehicle has been tuned, even if the tunes are removed before taking a vehicle in for service. I find myself hearing any new sound from these and freaking out, whether I should remove the tune just in case something blows up.
Beyond that, I've had a few things hiccup with tunes, things like turbo flutter. But in general, and I went with 5Star, the SCT Bully, they have been fairly quick to respond with fixes. I think you'll find several guys on here that work with smaller shops that may do a lot more complex tuning for you. But in general, 5Star takes all of your modifications and creates solid tunes.
bill_b
Pittsburgh PA
I have my 5 star, just have to load it in to mine... it was my last ditch effort to try to get the transmission smoothed out. I decided to go with them after my neighbor pulled the trigger for his 2018 F150 (3.5 EB) and was blown away by how much faster/smoother it is on their 92 perf. To be clear, I was not looking for performance at all... I just want my damn expedition to run correctly so I went with the 89 octane options and I think I had them throw 91 perf in but I have zero intentions of turning it up to that.
They are very hard to get ahold of... submit and email request form and tell them you tried calling and you'd like a call back.
Team_Z
Wa
Lots of grenaded Ecoboost online that were tuned hard....... just do your homework....
I was one of those on my F150, over tuned it and I still had Ford cover it under warranty. There is a process to getting covered (ex Ford Service Manager) had my transmission relaxed under warranty as well. Just make sure you always have the right octane. That’s one of the main causes for issues, the 3.5 is a very stout motor, can take a lot of abuse. I once drove an F150 over 500 miles redline the entire time, with all but 1&2 gears locked out. Long story short, was trying to find an issue 10 dealers couldn’t find and the owner was causing a ruckus. Finally figured out the customer just couldn’t afford the truck anymore and wanted Ford to buy it back. If you modify your truck to the point you can’t quickly put it back to stock the higher the chances of getting caught. But just a tune, not a tough problem.
Moderator
You bought a 5 Star tune to help your Trans? I am confused!
Moderator
Want the best device for tuning, an SCT device is not that device. But that is a discussion for another day.
Tuning only, E50 will give you the most power potential. I switch between a 93 Tune and a E85(Stock Pump Tune). Run the 93 tune about 8 months out of the year and the E85 in the warmer months, because more power and helps to counteract the higher ambient temps and what they do for power loss.
I don’t run a E50 tune on our Expy, because didn’t want the wife to have to worry about mixing. You can run full E85 with the stock fuel system, it is just turned back. MPG is decreased, but it makes this big thing REALLY fun.
We have a otherwise stock Expy, other than tuning.
I also use ZFG
93
E85
bill_b
Pittsburgh PA
Correct. I've ridden in my neighbors f150 whose was behaving very similarly to mine. Both he and I were thoroughly impressed with it out of the box. He has an 900hp turbo denali (self built and tuned) so he would not run this tuner if he thought it didn't help. He has ran his scanner with the tune for over 1500 miles now and only sent back the file to 5 star to make a few small tweaks that he said aren't really necessary.
His times, stock vs 91 tow/dd.
Please don't mistake me as someone saying every person who owns an ecoboost should call 5 Star right now. I only want my vehicle to run the way it used to before ford reflashed my computer 3x... so I'm trying this and if it doesn't work it's getting traded in lol.
NyackRob79
Nyack, NY
I find this to be a little hard to believe. First of all, Expedition is probably the LAST vehicle any dealer will expect to be "tuned". Mustang? Sure. Expedition? I bet they don't even look for it.
Now, if you bring it in with an aftermarket air intake and exhaust, they'll know they're dealing with a different customer.
But if you keep everything stock, a plug-in module (like JMS) that simply boosts the turbo a little extra for that +50hp is not going to tip off a dealer. You simply unplug the module when you have an engine issue and the dealer won't know anything.
Sure, they'll scan the ECU, and they may see the turbo was out of range. That's not a proof of a tune though. Dealer will simply assume a bad sensor, a bad turbo, or a simple anomaly. Those things happen all the time.
They're not going to deny you warranty service because some sensor readings were out of range.
The dealer would have to prove that you've tampered with the engine or the software.
Keep your Expy stock if you are worried about warranty service, and stick with plug-and-play modules like JMS if you want extra power.
If you do start customizing with bolt-ons, the warranty train has left.
kjf1
This engine was not design to run on E85 the seal on injectors and other area are not compatible. You are asking for trouble down the line.
houlster
AZ
I opted for an EZ Lynk programmer and Flex tunes from duramaxtuner. The flex tunes allow you to run a performance tune, but will adjust to the octane you're currenlty running. Any octane w/ E0 - E30 content. The higher the ocatne, the more power you get, but you don't have to re-tune if you're stuck with getting 89 for a fillup in a mountain area. The tow tunes are +50hp / 90lb-ft. Perf tunes are +100/100. They have E tunes for up to E85 that go higher as well. https://duramaxtuner.com/vehicle-type/ford/ecoboost/ecoboost-tuners.html
Separate tunes for engine and transmission & the trans tuning is pretty awesome. Very responsive like driving in Sport mode, but will still cruise in higher gears. Tunes only take a few minutes to load so switching tow/perf is pretty easy. I towed a cargo trailer @max gross from Phoenix to northern CO with the tow tune and it did great. Very happy with it overall. If you do a search, there's a few threads with info on it in the F150 / ecoboost forums.
Moderator
Wrong…totally and completely wrong. Any modern cars fuel system is 100% compatible with Ethanol from a seal and rubber standpoint. You are stuck in the past. There are TONS of F150’s running on full E85 daily. Hey, guess what, same 2nd Gen 3.5TT too. Zero issues.
Moderator
Excellent review!
Got any times in your Expy with 93 in the tank? Power claims are one thing, but real world numbers talk.
FlyBry
Dallas, TX
Perfectly happy with all of my 5 Star tunes.
The E30 tune is very peppy, bit no where near the E50 Tune = 565 Rear Wheel HP & 621 .lbs/ft torque.
I mostly run the E93 Performance Tune = 464 RW HP + 551 ,lbs/ft torque.
I usually run a blend of approx. a 40% E85 + 60% 93 octane gasoline (is already E10). With this combo, and the IAT below 50 degrees, you can easily achieve a little over 22 .lbs of boost; and roast a set of Hancooks in 1st & 2nd gear.
Absolutely love the shift improvements with all of the tunes.
*Last months big thread on Tuners = no reported warranty denials by Ford if using a tune.
Mike Wolfe
Tonopah AZ
Retired automotive fuel systems engineer here
Your statement is NOT CORRECT
Any engine built since the mid 90's has to be equipped to use at least 10% ethanol in the fuel
Whether it is 10% or 100% the same components must be used (O-Rings, gaskets, injector coil winding insulation etc.)
100% Ethanol is 112 octane
E85 is about 108 octane
It is a great fuel especially in boosted engines
Seems to be so much misinformation of ethanol
If the government would get their act together & allow the use of higher ethanol concentrations we would all be driving better performing vehicles
Ethanol is also a "CARBON NEUTRAL" fuel
FYI
I have owned 7 ECOBOOST vehicles all of the were recalibrated with Livernois or 5 Star tunes
No problems with any of them
houlster
AZ
Excellent review!
Nope, those are the listed specs for the tune so take it with a grain of salt. Nothing out of line with all the other tunes I looked at though, so not really suspect. I did not have it very long before adding the tune. It just feels good & very quick to me, and pulls like a beast with the heavy trailer behind it.
The tranny tuning is what I really like & notice all the time, every time I drive it. It's not just a WOT type of thing.
PNWExpy
Oregon
I just installed the 92 performance 5 star tune last week. A lot of extra pep and was really enjoying it but I only got about 120 miles outta it. It’s dropped outta gear 3 times since the instal while just cruising. After a decent thud it cuts all power and goes to neutral. Able to limp it home with no power/turbo. Doesn’t know what gear it wants to be in and then sends a few codes. I have an email in but I’m sure (after their two week vacation) they’ll tell me to redownlod the tunes and try against. It’s set back to stock for now!
PNWExpy
Oregon
Yeah I will say I haven’t really heard much bad about them. And what you do hear just seems like an unhappy camper who wants to poo on anyone.
But anyways, they sent a revised tune a week after I emailed them. It’s installed now with about 50 miles on it so far. No problems so far and it does seem better (the tranny learning stage was pretty bad on the first time). I’ll report back after a few hundred miles
