CCD vs. no CCD?
JimmyMcBob
My dealer gave me a 2021 Expedition loaner until my 2022 arrives.
The loaner has the CCD (Continuous Controlled Damping) option fitted. I like the idea of the CCD, but debating if I should modify my build to add it. I have not driven a Expedition without CCD.
Has anyone here been able to do a back to back drive comparison?
dlcorbett
Air Force
tx
Haven't driven any 22s, but from my feel, without ccd, a bit firm but controlled all the time. With ccd, overly soft, but better isolated. If yours has 22in wheels, def get the ccd for the protection it gives.
J
JimmyMcBob
Thank you for the feedback.
dlcorbett
Air Force
tx
There's a couple of people with my22s that have xlts,ltd, and krs, maybe they can chime in and let you know what they think of the ride so far.
One guy has an xlt, he said the ride was trucky and worse than an explorer whoch is bad news in my eyes. Another has a timberline, and said the ride was marginally worse than the air suspended wagoneer, which is great news(i driven one, the truck rides exceptional, see my review in general discussion). A few has a kr/ltd stealth and said the ride on the ccd was really good with the stealth sport being very well balanced.
bbenz3
I have a 22 on order with CCD but I've seen a couple starting to show up around me in dealer lots that don't have it and I'm wondering how much I'll miss it. Anyone know if it is something that could be added later?
caplanm
Boston
It is only available w/22" Tires. Definitely worth it. I have it on a 2018 Platinum. Not only does it compensate for the smaller sidewalls on the 22" , but softens certain things on the road, such as small pot holes, and expansion joints on the interstates
bbenz3
That's basically the conclusion that I had come to when I ordered. Unless it is one of the items that are in short supply then I'm surprised that all of the vehicles I've seen showing up on lots around me don't have it.
Gumby
Beaumont, Alberta
I do like the CCD when have full passengers and some cargo. I can switch it to SPORT and the suspension stiffens up and doesn't bounce as much. Alternatively, when cruising the highway I can set it to the leaf and it's cushy.
bbenz3
Well I guess I'll have to either wait or hope one with CCD shows up.
Soliyou
OK
The question about ride quality depends on where you are coming from. If your previous car was an F-350, then you will like the non-ccd suspension. Some 18-21 ccd owners complain about the bouncy feel.
If you are used to normal minivan/crossover driving comfort, then ccd will be more comfortable.
For me, the XLT suspension feels overly stiff unless the car is fully loaded, then it gets squishy and comfortable (normal truck behavior).
Anerbe
Mi
My experience in test driving multiple levels of Expedition (XLT non CCD, Limited non CCD) now in the Plat with CCD, the CCD makes a big difference on the lower impacts / lower load conditions. I felt the non CCD expeditions had more of a F150 feel to it - solid on impacts, but definitely meant to be loaded to be smoothed out.
From what I understand, CCD is magnetic ride tech - it feels very adaptable to different drive surface conditions, and the different drive select modes can be clearly felt thru the suspension.
techdude99
US
My '19 Platinum has CCD. It was unbearably bouncy (except in Sport) until I installed front and rear sway bars. Now it's passable but disappointing knowing Ford wasted a great opportunity to knock it out of the park.
The problem with Ford's CCD implementation is lack of user defined settings. The factory dampening choices along with motor and transmission shift combinations is not to my liking.
If I had a choice (not an option on Platinum models) I would have skipped CCD and gone with aftermarket shocks, springs, and sway bars.
That's my 2 cents but I'm probably in the minority since Ford decided to keep it simple for the majority of customers.
Wnomis
I had a 18’ limited on the standard 20’s it comes with and no CCD. It was definitely a bit more ruff of a ride then the 21’ platinum I have now with 22s and the CCD. It really depends what you want out of the vehicle. The “floaty” ride is nice on poor roads and for going over speed tables and such. I typically don’t put it in sport mode but when I do I can absolutely feel the difference and the ride is much firmer and for being the huge beast that it is. It handles the curves well in sport mode for what it is. Would I personally modify your order no. I also would not ditch my 21. The 22s just have not grown on me enough and I am tired of tinting windows
J
JimmyMcBob
Thanks for all of the great insight. Regarding my point of reference -
1) I used to have a 2017 F150 KR with the Off-Road package which resolved the overly soft ride of the F150. True, it was firm but I preferred that vs. the very soft ride I experienced in a 2017 F150 Platinum test drive
2) Up to getting my 2021 Expy loaner (with CCD) I had a 2018 BMW 3 Series - firm ride, but not as much as my previous F150. Driving dynamics totally different as you would expect.
3) Driving the 2021 loaner which has the CCD around Michigan - the low speed and highway speed ride is firm, similar to 3 Series. Up to now I have not noticed a difference in firmness between the driving modes.
Alwaysthinkin
Georgia
This thing, with CCD (and replacement sway bars), is a traveling marvel. Eats up the miles no problem. You'll be amazed how good you feel after a full day of travel.
Deadman
It really is. After the Hellwig sway bars, Its just a complete dream to drive on cross country trips. The factory sway bars almost makes you sea sick like you are swaying on the Titanic.
WALoeIII
I have CCD, Helwig Sways, and stepped down from 22" wheels to 20" wheels and really enjoy it for highway miles. Its too soft, especially in the rear, around town, but sport mode mostly mitigates this. I agree with earlier comments, I'd really like to separate suspension and throttle response/shift mapping buttons so I can run it in SPORT suspension but normal throttle mapping when I'm solo driving around town.
No members online now.
Landsbutter
