Shifting problems.
smith
georgia
My 2013 Expedition Limited with 125,000 miles has developed a transmission shift issue at 40 mph. Only does it for that shift sometimes. Any ideas?
S
smith
georgia
Was told by a Trans guy that the trans never needed to have the filter and fluid changed, only when it was used in extreme conditions. Obviously he must have been wrong.
Motorcity muscle
Motorcity
How do you re-set the computer in the transmission?
You disconnect the battery, then jumper the cables to drain the capacitors. Takes 15-20 min. to drain completely. Reconnect and then start truck and let idle with all the acc. off, computer will re-learn idle and then drive it easy to learn the shift points.
