A/C Problems
Ivan5
I am having an ac issue with my 07 expedition, using forscan the coldest the ac evaporator gets is 55 degrees, on my 13 F-150 it’s about 36 degrees at the same outside temperature, expedition was taken to the ford dealer and they charged the system to the correct weight, high pressure reading about 260 to 270 psi at 95 degree outside temp, F150 was at 200psi could this be a expansion valve issue or maybe they put too much oil into the system? Edit: Low side was at about 34psi on both
Motorcity muscle
Motorcity
High side pressure is too high, low side to low. Have you cleaned the condenser coil in front of radiator?
tvlunn
I will share a little information with you for what it's worth:
Based on what I've "heard" others say, this particular model Expy doesn't seem to have the best AC system. I say this because I have a 2008 Expy which I purchased NEW! Straight off the lot that very hot day in July 2008, I felt the AC should be able to do a little better. Since I have refrigerant, a manifold gauge set, vacuum pump, scales, etc., I decided the following summer to evacuate the system and refill. After the work, nothing seemed to change for the better.
This year, I noticed there was a little oil residue accumulating around the TXV valve. I went ahead and purchased and replaced the TXV valve and installed new "O" rings. I then vacuumed the system. I pulled the system down to 500 microns. With the vacuum pump off, the system then held for 30 minutes at 500 microns, so I knew there was no leak present. I weighed in the appropriate charge and the system is back to "ITS" normal. It cools and keeps the Expy comfortable but my 1998 Expy and 2015 Jeep do a better job.
At 93 degrees outside temperature, my 2008 Expy puts out approximately 50 degree air at the center vent. Pressures were 260/33 on the day I completed the work I mentioned above.
My 1998 EXPY easily puts out 40 degree air on a comparable day.
Hopefully, this info will help in some way!
fireguy926
MD
My 2012 Expy has never had great A/C. Especially on hot days at beach, does not cool well at all until I get on the highway for a bit. Condenser is clean, just the way its always been.
Motorcity muscle
Motorcity
OP truck is older than yours, why I started with clean condenser. Every system can be repaired, start with simple and troubleshoot with system pressures and temperatures.
bman440440
san diego, ca. USA
I have found with my 08 if the rear AC is off the front AC doesn't cool as well... on a 90-91 degree day with the rear off the center front vents get down to 49 or so... with the rear on the same vents get down to 39 degrees... on my 01 and 06 the where similar(3-5 degrees difference)... but on the 08 it was a bigger(10 degrees) difference between on and off.
fothco
BC
My 2013 Expee -Max Ltd now has had 2 AC Compressor replacements . Costly . Only 130,000 kms on it . 5.4 engine . Is it correct that mechanics must only replace AC Compressors with same brand , make , & model unit ..??
Dustin Gebhardt
Tulsa, OK
My 2007 had poor AC performance until I discovered that the temperature sensor inside the evaporator box was reading low. It would cause the compressor to shut off, thinking that the evaporator had reached freezing temperatures. It's located behind the glove box. I placed a 330k (IIRC) resistor across the two wires in the sensor. This drops the total resistance of the sensor and causes the compressor to run longer, as it thinks that the temperature is now higher.
With this setup, I get into the 20'F - 30'F range frequently. The downside is that on long road trips, the evaporator will ice over completely and I have to turn off the AC button for about 30-60 seconds for the ice to melt, and then I'm good for another hour or two.
I would simply replace this $20 sensor, but I'd have to remove most of the dash to get to it. A $0.10 resistor works for now, until I need to open up the dash for something else.
tvlunn
That's very interesting Dustin!
I need to check into that myself. That may be my primary issue ............... and likely is!
Is the wiring leading to the sensor you mentioned easily seen once the glove box door is opened or removed?
One could likely determine the "error" in the existing sensor and then place an appropriate sized resistor across the existing one to make it read correctly. At least that is my thinking for now!
tvlunn
Trainmaster,
>> Are you referring to the temperatures and pressures I had mentioned (tvlunn)??
Also, when I get a chance, I'm going to take a look at the reading of the sensor Dustin had mentioned in his post. I'm assuming I should be able to get a reading after it has sit overnight in my garage and then compare it to the ambient air temperature. That should tell me if the sensors reading is accurate/close enough OR how much error is in the sensor!
I
Ivan5
After cleaning the condenser and turning on the rear ac I was able to get the evaporator temp down to 39 degrees without changing or adding anything, thank you to everyone that helped
Motorcity muscle
Motorcity
Thanks for reporting back that you got it working. My '07 @ '09 both cool very good so it doesn't seem like there's a design issue. When it's hot out I keep the control set to recirculate.
I
Ivan5
So the issue happened again with the warm ac, I was getting 72 out of the air vent, I replaced the temp sensor in the evaporator box and both front and rear expansion valves which brought the vent temp down to the mid 30s.
