Not sure if this thread's too old, but before I post a new one....maybe someone here will know the answer. I'm suspecting a problem with that same PCV "valve" on my truck. However when I took it out and look at it, it's just a piece of pipe with a 45 degree angle at one end, there's no "valve" inside it like a normal one. You can see right through it with a flashlight.
The truck has had these symptoms and I personally rebuilt the engine last year: When engine is cold, unable to pull into traffic because engine is popping out of the intake (running extremely lean), won't rev beyond 3K rpm, high oil consumption, intake manifold makes a rattling sound deep down inside, get codes saying all (4) O2 sensors "stuck lean". I've done all the obvious things like change the fuel filter, even replace the fuel injectors with new, changed all O2 sensors, the exhaust and cat converters are brand new (so I know they're not blocked), new MAF sensor, fuel pump is pretty new and it's getting high fuel pressure (my 60 psi gauge pegs out so it's something much higher than that).
I was thinking that intake rattling was those little metal valves/doors that are inside the intake manifold, but now I'm wondering if it's the guts from the PCV valve if it fell apart.
So before I go buying that PCV valve, do you know if it's supposed to be wide open with no check ball, or is mine totally shot?
