UCA question
Logan97
AZ
I've read through a lot of threads on here and can't find a definite answer. I will be lifting my 07 expedition 2.5in, do I need to replace the uca's or will they be okay with this lift? If I need to replace them please recommend some and if there's anything else I should do let me know. I've only ever lifted one vehicle in my life and didn't have to worry about replacing anything else, so I want to make sure I do this right before taking everything apart.
Frank Wilson
PlymouthMA
You will be fine going 3" front, 2" rear. Over 60k on my UCAs.
These aren't Baja Racers and will never be boulder crawlers, so "droop (or drop depending on what youtube vijayos you watch ) " is irrelevant.
L
Logan97
AZ
I only use this thing on some dirt roads, desert driving, and occasionally through the woods up north, nothing crazy. Definitely would never rock crawl in this thing, be to scared to damage the underside
Expedition Dave
A Tiny Little Dot in Florida
FYSA:
By adding things like longer shocks or coil spacers, you will bottom out even sooner b/c you have already maxed almost 2/3rds of your downward travel by simply raising your vehicle.
My 2 inch shock lift bottoms out my front UCA on my spring. That means it does so FOR EVERYONE lifted past a certain point (w/o aftermarket UCAs)
I can assure you, it does not take much to lift a wheel if you go off-road (ask me how I know) unless flat/beach/gravel/sand/snow road stuff and there are no undulations or ruts and you don't drive fast over bigger bumps.
Further, if your UCA gently hits your coil--which for most people here if they droop--it will damage nothing unless somehow it gets caught and even then probably will pop out easily.
Just go into it with full knowledge.
What this guy is doing is not even remotely excessive, andi f this was our trucks (w/o aftermarket UCA) you will be hitting your coil spring at max droop (as seen here) because droop is increased with certain lifts.
Roast4570
I was worried about it too. I threw new UCA’s on it as they were thicker and had changed the angle of the ball joint to keep the ball joint from being cranked to the max with the lift. Freedom off-road.
L
Logan97
AZ
How long have the new one's lasted?
L
Logan97
AZ
FYSA:
Are there any other pieces I should change out while I'm in there? Everything is stock on mine except the rear suspension I took the air bags off and put regular shocks like the front. Personally I don't trust air bag suspension unless it's on the bus I drive.
L
Logan97
AZ
The UCA's on freedom off road, did you buy the black or silver one's? I like the look of the black but the silver sounds like it'll be more durable based off description.
Roast4570
So far they have been on for a few months, haven’t had any trouble yet. I went with the black ones. I have an 08.
L
Logan97
AZ
So do the lower control arms need replacing too or are they okay? No one has mentioned those.
Roast4570
Not really. I just replaced the lower ball joints when I did everything else. Those were completely trashed. But I didn’t notice any fitment issues at all.
Expedition Dave
LCAs are fine. Also, UCA bear no heavy weight they are there for allignment through the suspension arc. The LCA supports the weight of the truck.
*I am no expert, and learning as much as I can about IFS and IRS as I can* NOTE THESE ARE ALL GEN4 Specs:
I believe the front suspensions "bump stops" are the strut's limitations.
And from my conversations with Bilstein Techs and ICON techs (no Ford techs) I have a "feeling" that the Gen4 zone is 1.6 inches max lift before your factory UCAs will hit the coil (Bilstein 5100s) on the droop and a max lift above that will require a new UCA (ICON 2.25 height coil overs but their shock linits too much downtravel).
Guys with 3 inches of lift and aftermarket UCAs may overstrees their front axles--but IDK about this at all--just specualtion.
If I had a garage and lift, it would be fairly easy to determine I think.
Frank Wilson
PlymouthMA
The front drive shafts must experience increased "stress" with the 3/2 lift. Maybe just more resistance at the joints?
L
Logan97
AZ
What about 3rd gens?
Roast4570
So I noticed at 2.5 inch spacers on the front, my aftermarket UCA’s would still rest on the coils when the front end was off the ground and suspension was at full droop. That being said, I haven’t heard any clunking on speed bump or with pot holes at all, and the thicker pipe construction on the UCA’s I installed seem to be less prone to hanging up in the coil.
