juan214
Checking fuses next.It is in between the battery and the starter somewhere. follow the positive cable to it, or go to the starter and follow positive cable back to the solenoid.
there is one there it locks the shifter in park. Check brake light switchThe click I hear when trying to start sounds like it's coming from the center console. Probably a shift lock solenoid.
OKthere is one there it locks the shifter in park. Check brake light switch
Ground post to Starter Negative Post .000cables on the starter, negative terminal on starter to ground post on battery, From the positive post on battery to starter positive terminal. Both at rest and while trying to start.
I did follow the cables from the starter to the battery. They go from the starter towards the front with a couple of lines. Then up the right side of the radiator then to the battery. Found nothing along the way but looms.It is in between the battery and the starter somewhere. follow the positive cable to it, or go to the starter and follow positive cable back to the solenoid.
There have been many threads of no start that have ended up being the brake switch. The brake lights might be working but still not activate the start when you press on the brake.Checked it any way, my son says the left light is out the top right.
I thought that that switch has to do with Shift lock solenoid not unlocking.
