Let's See Those Lifted / Big Tire Gen 4s!!
Coop7379
Jacksonville fl
Here is a better picture of the rear wheel well. Alignment and bigger tires scheduled for Wed. I only added .7" (middle slot) with the bilstein shocks on the back on top of the Rough Country. There was only about 1/2 " of clearance at full extend between the axle and frame. Any more than that lift and it would end badly.
lefty hack
Vegas
2020 FX4 Max
I did the standard 3/2 Lift
Found some brand new OEM Raptor Takeoffs (wheels and tires) BFG 31570R17
No rubbing...a little bit of poke but not much...(which may be why they don’t rub!)
And just installed my Raptor style grille on the front!
Oh and swapped out all of headlight, fog light, and backup halogen bulbs for LED’s.
At the moment, we are calling it the RaptorEx Edition!
Where did u get and did u have to modify anything to make the raptor grill work?
Coop7379
Jacksonville fl
I do not have a raptor grill, I want one. I know one modification will be getting the front camera mounted, atleast with the one from summit
LazSlate
Arizona
Expy Gator
Is this the stock Timberline factory lift? I have a Timberline and have been looking for a while to see if anyone put 35s on it stock.
I mounted my 35x12.5x17’s on the Timberline from my Raptor. I posted pics earlier in this thread - I thought it was a little too close but they will work. I ended up going to 295-70-18 will prob upgrade in the future when more suspension options are available.
LazSlate
Arizona
Im on the fence with stock rims with 295-70-18 or the Method 703 with 295-70-17. The 703's are the only rim I could find with a decent offset. The factory is 44 and the 703s are 25. Trying to avoid wheel poke.
HtownHog
Houston
Moto metal, XD and American Racing all have the bigger offset options but they are only 8” wide wheels.
Lou Hamilton
BTW, Timberline offset if 39, not 44. All other models are 44 as far as I know.
The 39 is stamped right on the inside of the wheel.
Hectorsvt
TEXAS
Pulling the trigger on the RC 3 inch lift kit with the UCA's on my 18' FX4 xlt. Does anyone have a pair of blistein 5100's for sale for the rear? To replace my stock shocks? ...also I'm wondering if I could get away with throwing some 35's in tires with the stock FX4 Wheels or go a tad bit of a smaller size?
sjwhiteley
Kentucky
I got my bilsteins from summit racing at 150 bucks each, a couple of weeks ago.
GDYSTEALTH
Edmonton
IView attachment 71351View attachment 71352I I just traded in my stock 22" wheels and tires (which in my experience were minimally capable in snow), for Black Rhino 22's and some tires with more meat on them. I wanted more capability and slightly more aggressive look without going for the full off road look. Ultimately i decided against suspension mods at this time. This expo will see plenty snow, but nothing off the road. Very happy with the outcome. NO noticeable difference in ride or tire noise, no rubbing. On 22's I believe this is as large as you can go without mods to suspension.
Specs:
22" Black Rhino Kunene 9.5 30 (i think)
Toyo AT3 305/45/22
I like this setup where where they from if u don't mind my ask Im trying to locate in Canada but hard to find stock?
Expy Gator
I have had zero issues with the Recon Grappler 295-70-18 on the stock Timberline wheels. It fits the body lines well. I have 35x12.5x17 on my Raptor but when fitting them on the Timberline the clearance was tight so I went with the 295'sExpy with Nittos.jpg
