2018+ Fuel Filter location?
TheDoug
Mansfield, TX
I searched the forum and got no results for this... I haven't looked at my vehicle yet but wanted to know where to start before I started this.
Is it on the frame some where near fuel tank? Anyone have pic or diagram?
Thanks!
BMW2FORD
CT
On the 4th gens it’s in the tank but I don’t think it’s replaceable separately without changing the fuel pump module. One thing on all the cars I’ve seen is the in tank filters are pretty big a do seem to last a lifetime unless something real bad happens like contaminated fuel so no need to change it like a maintenance item.
TheDoug
TheDoug
Mansfield, TX
Thanks! That explains why I can't find info on the filter replacement on 4th gens.
Alhrir1982
SAUDIA ARABIA
This is fuel filter
TX-EXPMAX
Hard to tell from your pictures you posted, but where is it that you depressurize the fuel system? almost seems like it's inside the kick panel or somehwere in the back of the vehicle? As for the filter itself, is the skid plate near the tank? I haven't crawled under there yet...
m3olsen
CNY
Interesting thread! According to the 2022 owner's manual, pg 404:
There is also a reference on pg 533 that if you register your vehicle in California, failing to perform fuel filter maintenance item does not void your emissions warranty. I see no reference to a fuel filter service in the service charts.
I looked up the PN off the box that @Alhrir1982 shared, and - at least on Carid - says it's for a 2018-2022 Navigator.
It's unfortunate if our manuals aren't identifying maintenance items.
5280tunage
colorado
Looking at the quick disconnects in the images, is there a depressurization/pressurization process? One would think the air in the filter needs to bled off before making it to the fuel rails.
m3olsen
CNY
I wonder how you perform step 8 to cycle the ignition key and wait 3 seconds on an Expedition with pushbutton start.
ETC13
TN
So what is the story here? In the tank or not? Manual says in the tank, but this thread says no and yes.
Rob6805
There is NO external fuel filter on these vehicles nor has there been with any Ford's for quite some time. My 2010 F150 doesn't have one either...
Mr Big
Tampa Bay, Florida USA
Definitely no external fuel filter. It's in the fuel tank as part of the fuel pump and requires no maintenance. If you are experiencing rough idle, slight loss of power, sluggishness, hesitations, there may be an oxygen sensor or catalytic converter issue. My 2019 Platinum was idling rough on startup and sluggish at times. It turned out to be an oxygen sensor that was dirty.
