Does the ODB2 output transmission temp info - Gen I Expedition??
Tjhoward84
Bothell, WA
Wondering if there is a way to read the trans temps from the ODB2 port on a Gen I (1999) expedition. I have an external trans temp gauge on my A-pillar but it would be nice to get another data point to check how accurate my aftermarket gauge and temp sensor is.
sjwelds
Kansas
Wonder as well but rather doubt it. Reason is I'm not sure if even the 3rd gen outputs trans temp. I have a Bluetooth adapter and the torque app and was trying to find it the other day on my 2012, and couldn't figure out how to make it work.
ExplorerTom
I bought an UltraGauge for my 2000 and had them program it to display transmission temp.
Then when I sold my 2000 and put the UltraGauge in my 2014, I had to work with them to figure out the code to display it.
So yes, it works on both.
ManUpOrShutUp
3rd gen does.
tekrsq
Chesterfield, Va
The 1st gen will certainly display trans temp. I have an XCT hooked up to mine, as well as an A pillar gauge routed to the pan. I like having the 2 gauges because it lets me know what temp the trans is operating at, as well as if it's being transferred to the pan oil. As long as my pan oil is cooler than the operating temp, I'm good. I've thought about routing the pillar gauge to the test port on the driver side, to compare those 2, but I'm monitoring the things I want to. So haven't really been a hurry to screw with it.
mhg1
sav, ga.
Kind of late to the thread. I have an XCT on my 06 and it shows the trans temp.
Mike
Tjhoward84
Tjhoward84
Bothell, WA
Do you have a link to the XCT? I have the A-pillar gauge monitoring trans temp too. I think my gauge is hooked to the test port on the drivers side. What do you have your XCT hooked to?
