Dexron VI?
callwill
WNY
Went looking for tranny fluid for my 2011 4x4 xlt EL to do a fluid change. I was shocked to see Dex VI was rec'd at a couple places and web sites.
8 qts for the pan drop?
What and how much do i need for the
Transfer case?
Front Dif?
Rear Dif?
C
callwill
WNY
Owner manual says transfer case fluid for the transfer case. Thought i saw that Merc LV can be used...
ediddily
Nevada
For my 07 XLT, no manual with car, but what I found was it recommended MERCON V or something like that in the trans and transfer case. I used to hear a loud click in the transfer case when shifting prior to changing its oil. Now I don't hear anything hardly when it shifts.
WEDGE
Kimberley BC Canada
Ford Transfer Case Fluid has been superceded by Mercon LV, safe to use in cases that called for transer case fluid previously. Also DO NOT use Dexron VI, that is for GM
