duneslider
I'm certainly no expert here but I think there are multiple things going on and not just a thermostat issue. There have been a lot of issues with thermostats not working correctly and for some reason ford has change the replacement part to a lower temp thermostat. I think the original stock thermostat opened at 203-205 the new ones appear to be 190deg. An improperly functioning thermostat obviously is a problem.
Since these are also forced induction I think there can be other issues that may be attributed to heat soak so the better you can keep the engine cool initially the less likely that is to happen. Once they get to a certain temp its hard to get them back down. Most problems seem to happen in prolonged high load and low air flow. You have a better chance at keeping this in check if the cooling starts at a lower temp.
Ford is trying every trick they can to get a little more epa efficiency out of it and so if the most efficient running temp is higher they want to try to stay there even though that may not be the best for everyone's situation. I have only experienced temps climbing when I have been at higher altitude 8000+ feet, heavy load, high ambient temps and going slow. Last time I went to this area there was no traffic and I was able to maintain 35mph (speed limit is 25mph) and I had no issues but on previous trips when I was in traffic and had to go 25mph things would get hot. Once I hit the dirt I put it in 4lo and that decreases the load on the engine and even though I am going even slower the temps quickly move back down to normal operating range. My theory is that if the engine starts cooling at a bit lower temp I might make it further up the hill before I start seeing the temps get too high.
It also doesn't help that the radiator is trying to keep the engine cool, the oil/turbos cool, and the transmission cool. It is probably undersized for needing to do ALL that work.
