Caliper Fail
F150 Pat
Sugar Grove, Illinois
Out today about 10 miles from home and the brake pedal was gradually going all the way to the floor. Little bit after that my wife hears something scrapping and then sees something come off the vehicle and hit the curb. I go up about 2 blocks and turn off where I can stop and see that my RH rear wheel and brake assy is soaked if fluid and dripping. We start back home very cautiously and we see the part that come off. It was a caliper piston. Ive been doing brake jobs for people and family since high school. Never saw anything like this. Nobody has touched the brakes since it was built. All Factory. Got to the dealer and they were just shaking their heads. They never seen that happen either ever. Anyway here is a picture. Looks like the caliper bottom bolt or nut broke off for the slider pin. Top is fine. It's under an extended warranty so this should all be covered. Tomorrow I'll find out more.
SyndicateZ
Mass
As long as you havent had your calipers painted (by anyone other than Ford) they should cover under warranty.
Zig10
Mid Atlantic
You're missing a guide pin bolt on the back, too. Wonder if something smashed against it hard enough to take out that bolt and damage the caliper housing.
VBreithaupt
I know someone who had the same thing happen to them. The pin worked its way out( after a brake job) and the caliper shifted up. When they hit the brakes the brake piston blew out and they lost all brakes. What sucks is you don't have an emergency brake pedal to push down.
SyndicateZ
Mass
While moving, U can still "slow" the car by holding up the parking brake lever and the vehicle will eventually come to a stop
F
F150 Pat
I used the emergency brake and manual shifting to get me back. Anyway the dealer submits all warranty work to Ford online. There is nobody to call or email. My vehicle sits at Ford on the rack with all parts in stock but the dealer cant do anything until Ford gives the go ahead. They said it could be up to 72 hours. So the customer could sit with no vehicle for 3 days while ford finds time to ok the warranty. And it could be longer if they require more information or pictures. Insane.
SyndicateZ
Mass
Dealers (Ford) should be required to offer a courtesy vehicle while they make customers leave their vehicles sitting on their lot for day(s) while they pick thier noses and ponder if they should cover a Obvious warranty repair.
Zig10
Mid Atlantic
Especially since it's about a $250 fix. Sadly, this is the BS that is dragging Ford's reputation down.
F
F150 Pat
Well it a caliper change, brake pads on both rear wheels and a couple of brackets. Rotors too. Kind of pricy if I had no warranty.
I wish you luck.
I purchased a new 2015 Expedition Limited 4x4 - my first Ford.
Many times I had warranty repairs performed - and now repairs under my Ford Premium service plan. Often the dealer had to get permission from Ford to perform the repair - although it was obviously a coverage failure. This delayed the repair, delayed ordering parts and left me without a vehicle.
This process (and Ford’s poor quality) is one of the primary reasons that I’ll never buy another Ford.
Ford does not trust their authorized dealers to perform basic repairs under their warranty.
F
F150 Pat
I agree. Im in Day 3 now and this will surely go to Monday now with no vehicle. We have 2 vehicles but it's clearly a warranty issue. Why the dealer cant make that call is beyond me.
Sorry to hear about your situation. Scary indeed. Hope Ford makes this right. Modern cars have a tandem master cylinder, so if the back system goes out or leaks, the front should work unaffected or vice versa. I think this feature was federally mandated back in 1967.
F
F150 Pat
I have 49,300 miles on it
got it back yesterday. Ford had it 6 1/2 days. Over the weekend but still. It took ford 3 1/2 days to approve a clear cut warranty issue. If I was a mom with 4 kids I would have been screwed. Warranty approvals should be done within hours. Something clearly wrong with the entire process.
