Rooftop 2-way radio antennas
Left Coast Geek
Mid Left Coast
I will need a GMRS 2-way radio in my Expedition next year for an extended caravan... I've been advised that the handheld FRS/GMRS 'talkabout' stuff doesn't have adequate range... The GMRS radio I got, a Midland MXT115, has a magnetic antenna.... Oooops! The Expedition has an aluminum body?!? muahhhhhh.
I suppose I can use a double sided tape disk to hold it down ? :-/ But I kind of wanted to be able to put the radio away when we're not actually caravanning (maybe 1 in 4 days of this trip is travel).
rd618
new york
Use 3M Double Lock it’s like velcro but commercial quality.
Left Coast Geek
Left Coast Geek
Mid Left Coast
Industrial velcro is an excellent idea. I was thinking of just cutting a disk of iron/steel the size of the antenna mount, and attaching that with a VHB disk, then using the antennas magnet base as-is.... hopefully I can remove the vehicle side after this trip is done and clean the adhesive off the paint without damage other than having to re-wax or whatever.
Gary Waugh
Princeton, TX
I have a 2008 expedition and use a magnetic antenna mount? When did the expedition’s switch to aluminium roofs?
rd618
new york
The one I’m suggesting does peel off once you apply a bit of heat, just do it slow, if not it will remove the paint too.
Depending the weather, you might want to bring some extra with you. If temps on the roof get over 120-130 the adhesive becomes more playable, add in water and it becomes less strong.
Greyeagle
Manchester Tennessee
I don't know what type of antenna you plan on using but...
On the old CB radios we needed a gound plane to use as a receiver... the whip antenna is just the transmit side. On a metal roof the magnet sticks to the roof metal to form a ground plane for receiving.
They do make antennas for vehicles that doesn't have a metal roof like a motorhomes that use fiberglass or now adays rubber.
Any communication shop can assist or point you in the right direction..
Left Coast Geek
Left Coast Geek
Mid Left Coast
Well, GMRS/FRS uses a little short whip, its like 462MHz UHF (CB is 26 Mhz AM, much longer wave).
The Expedition roof is aluminum, so it will serve as a ground plane, just non magnetic...
Greyeagle
Found this online...
Maybe it will help.
What antenna do I need for a GMRS radio?
Easy, you can use an NGP or No Ground Plane required antenna. We have found that the best antenna for GMRS radios where little to no metallic ground plane is available is the RFMAX RBC-450-5-NS. The RFMAX RBC-450-5-NS is a UHF whip antenna with an NMO base and NO metal ground plane required.Feb 3, 2021
Left Coast Geek
Left Coast Geek
Mid Left Coast
as I said, my roof is aluminum, so should provide plenty of ground plane. I'm using the antenna that came with my Midland MTX115 only issue is attaching it, since the antenna's magnetic base won't stick to aluminum.
rd618
new york
The 3m stuff I recommended already. The grounding plane is not relevant. You are also attaching it to a painted surface, which is a terrible conductor. Just go with the 3m double lock.
rd618
new york
Another option that’s removable and more sturdy, get a piece of 1/8” steel from your hardware store and bend it to mate to the surface on the inside of the roof rail. Use 2 of the existing holes to screw the plate against the rail and then magnetically attach the antenna. More labor intensive, but might be even better.
Going_Going_Gone
Phoenix
Or...if you have a moon roof and won't be using it on your journey, you could open the shade screen and hold a moderately strong magnet (observing correct polarity) against the underside of the glass while someone else positions the antenna above it. Retract the screen and no one will be any the wiser. To avoid scratching the glass, apply felt to the two surfaces in contact with the glass
Retiredusps
N.J.
iF YOUR EXPY HAS ROOF RACKS sUPPOSE YOU USED WORM GEAR CLAMPS TO ATTACH A SECTION OF STEEL PLATE TO THEM.CUT 4 SLOTS BIG ENOUGH TO FEED CLMPS THRU THE STEEL.
sixstring
Find a suction cup mount. I use a suction cup mount for a gopro at over 100mph and it is fine.
XeBeast
FTW
I would get an antenna mount that attaches to the roof rack like this one.
RS-660U Comet Adjustable Pipe/Roof Rack Mount Max Opening 2.5" x 2" https://a.co/d/fqcEMjw
chuck s
ku3r
New Jersey
I use this on my 2021 - though I suggest some quality 3M door edge tape on both the fender edge and hood edge. The mount is secured by one bolt, and while mine hasn’t rotated, I’d expect it to take some paint if it did, does… Hopefully the tape prevents that.
As for an antenna, Just get a larsen NMO mount 1/4wave and cut it per the instructions for GMRS frequencies.
For the NMO mount, I can’t find the link now, but it may have been made by Diamond and had very small coax that was “easy” to route through the rubber feed through behind the glovebox.
00spy
West Newton, PA
Get a round electrical blind plate for an outlet box. They cost 88 cents at ace. Get some double sided gorilla tape. Put plate wherever you want. Mag GMRS antenna will not come off unless you slide it off. Did this for a 2020, 2021 and my 2022 SPP as well as an F150. I use 2 antenna's, one for CB the other for GMRS.
Hellwig
I have a Weboost Drive Reach device and its antenna is magnetic too. I just use the roof rail to attached it when I need to. Both rails are steel, at least on XLTs.
