Here you go. Let me know if you want others.Can you post more pics at different angles?
Here’s with the wheel turned. Closest spot on both sides. Only has rubbed when I cranked the wheel hard off-camber in a parking deckCan you post more pics at different angles?
Hey there yall, can you run 33 X 12.5s on the stock expedition rims.
Not sure if you’d be interested, I did see rough country had a 1” level for CCD. Not the half inch you’re looking for, perhaps looking for an f150 .5” level (I’ve owned many f150s, I’m sure there’s one for them that may fit ours)No lift, but with Raptor beadlocks and 315/70R17 BFG A/T2’s. A little bigger than I wanted, but couldn’t beat the price. I didn’t care for the 22’s that came on the stealth. I had to pull the front half of the front fender liners forward to clear. I already had the air dam off, so it was pretty easy to make new holes for the liner where it attaches to the bumper. The driver side running board was too close when turning, so I adjusted it back. Anyone else with deployable running boards run into clearance issues?
Is there a bottom shock mount leveling spacer? I’ve done several on GM’s, but can’t seem to find one for Ford. I’d like to get a 1/2” to get it perfectly level.
Not sure if you’d be interested, I did see rough country had a 1” level for CCD. Not the half inch you’re looking for, perhaps looking for an f150 .5” level (I’ve owned many f150s, I’m sure there’s one for them that may fit ours)I went with a F150 1/2” level and it worked fine. The 2/1 RC option is more intriguing, but the front-to-back height was only off 1/2”, and I hate the front higher look. The 1” and 2/1 are definitely new.
Yes, the F150 wheels will not fit the back axle. Need to trim it back about a quarter inch to get the dust caps on. I did mine with a sawzall.I read elsewhere that not all F150 wheels will fit? Something with the dust cap.. and the axle may need to be trimmed…?
Currently looking into F150 take-off either 18” or maybe even 17” wheels. Anything to look out for when staying somewhere stock 275/65R18 or 275/70R17 ish.
I like those Tremor Y wheels, or the base Raptor ones optically.
Not looking into doing any lifting etc.
TIA
Correct. Rear center cap doesn’t fit with the axel length. I’m running without the cap until I have a chance to trim the axel down. Should be able to see it in my pics. There’s another thread on here about Raptor wheels and tires that shows it too.I read elsewhere that not all F150 wheels will fit? Something with the dust cap.. and the axle may need to be trimmed…?
TIA
