2022 Expedition XLT 13.5 mpg
fordfordford
mesa, AZ
Hello we recently purchased a clean 22 XLT, Max Tow pkg. with about 10,000 miles on it. We did a leveling kit and are running 275/60/20 tires. This vehicle has averaged around 13.5 mpg for the past 3k miles and I am wondering why it doesn’t do any better? As far as hwy miles we have only driven it up to the mountains and back with lots of gas guzzling hill climbs. Tomorrow we will be driving to Topeka KS so we will be able to get a better idea of mpg between fuel stops. How much should I expect on our long drives across Texas and Oklahoma at 75mph? Does Eco mode make much of a difference? My 2020 F150 with Whipple Stage 2 kit and 285/75/17 does much better than this truck, around 16 mpg around town if I drive light footed. Anyways I hope to check in this week with some real time data. Will run the tires at 40 psi all around. They are FALKEN wild peak at4w load range D.
ib_jigged
NW MN
Are you checking mpg with the vehicle computer, or actual calculation of fuel used and miles? When you went to the larger tire did you have the computer changed to the new tire size? If you did not have the computer updated and using the dash MPG, the calculation will be off as you are running a 3% larger tire now. Also with a load range D over a standard SL Falken Wildpeak AT4W you added 10lbs of rolling weight at each corner. Added rolling weight will always contribute to lower MPG, not much, but it will be lower. I basically did similar tire size and weight change to my 2012 F150 3.5 eco boost and went from avg of 20mpg highway to just over 14mpg and that was having the computer updated. Truck looked better, but that comes with a price.
BigOleFordFan
Zoom Zoom goes da "Tang" !
Army
^^THIS^^
Bigger tires = more weight = lower mpg... no doubt about it :D
And adding 40Lbs of weight to an already heavy vehicle will do you no favors in this respect, similar to what happens when towing something...but then it's even worse due to the additional friction & resistance...
And the fact that you are driving @75mph isn't helping either.....same as above: more speeeed = lower mpg !
Benztech
What axle does your F-150 have? I'm guessing is has a 3.31 based on your stated MPG. The Max Tow expedition has a 3.73 rear end- more pull at the expense of MPGs especially around town.
Pawpaw
Raceland, La.
I've got a '21 FX4 with the max towing package. 3.73 gearing..brake controller and the back up assist. I get a constant 16-17 mpg around our little country town with 45 to 55 mph speed limits. On the highway 21-22 mpg depending on speed and road conditions. I live in flat as a pancake Louisiana but did average 19.1 mpg on a 1400 mile round trip to Branson, Mo. and back. I'm running 33 inch BFG KO2's but I usually just run the posted speed limits or under depending on weather. I usually run 87 octane but when towing our 8K pound camper I'll up it to 93. Keeping out of the turbo's will give great fuel mileage!!
2020-MAX-Limited
Colorado USA
Last Fall, we took our '20 Limited MAX on a roadtrip from Monument, CO to Alamosa, CO, Antonito, CO, Chama, NM, Pagosa Springs, CO, over Wolf Creek Pass back to Alamosa. We left Monument with a full tank. Upon getting back to Alamosa, we filled up and the range to empty was over 700 miles! The MAX has a 33 gallon tank, but we have never seen anything much over 500 miles during normal daily driving. The fuel economy display was over 22 MPG where normally it hovers around just over 20. Thus the steady highway driving greatly improved the MPG over the normal city driving we do. We have 20-inch highway tires, AWD vs. 4X4 and no towing package.
You answered your own question: “As far as hwy miles we have only driven it up to the mountains and back with lots of gas guzzling hill climbs.”
Mr Big
Tampa Bay, Florida USA
So many variables happen determining gas mileage. terrain, tires, gross weight, etc.
Here on the flat roads in Florida, I get 18.2 mpg city and over 25 mpg highway at 65mph. One trip to Atlanta, in eco mode I achieved 28.2 mpg all highway.
duneslider
Utah
I see 12-14mpg for the short around town trips we take. That is fairly normal. It doesn't get better mileage until it is on open road. I never noticed much better mileage in eco vs normal, maybe it was slightly better around town but not enough to matter. Once on the highway at a steady pace it doesn't matter if you are in eco, normal, sport, mileage seems the same.
C Trost
‘20 XLT HD Tow, Just drove from Md to Ohio over App Mts, in/around town for long weekend, and back. 70-75mph on hwy. 22.6mpg. With a full vacation load and pulling my boat 600mi Md to KY at 70mph I get 14.5mpg. You have something wrong somewhere.
cloudmech
When I hear what some of you are getting for gas mileage, it makes me think about actually getting a new Expedition to replace my 2003 Expedition FX4 that only has 116,000 miles on it and gets about 13 to 13.5 mpg. But, since I work from home, why make payments when this lifted 4X4 takes me anyplace I want to go? I don't know if it's still the case or not, but my '03 weighs in at just under 3 tons. That's part of why driving in the city with big, heavy off-road tires kills your mileage.
Deadman
You lifted the vehicle so it sucks more wind/air, its never going to get good milage on the highway like that. Ford lowered it down for a reason, not just so it looks gross....
SyndicateZ
Mass
I have HD Tow with the 3.73 gearing and get about 12-13 (alot of stop and go) city driving with (ASS) OFF. I get about 20-22 (highway) somewhat level roads
Left Coast Geek
Mid Left Coast
I have HD Tow on my 2019, and have seen anywhere from 9 to 15 MPG towing, typically 12-13, and 12-22 open highway long distances, according to the dashboard computer. when I've crosschecked it manually on random tankfuls, its been pretty close, within the tolerances of how much gas might be in that 'full' tank. I've also cross checked the trip meters mileage readings against google maps, again darn close. Other than mountains, the single biggest factor is speed. oh, premium gas doesn't seem to change a thing
fordfordford
fordfordford
mesa, AZ
Thanks for all of the replies!
*when purchasing the tires I was aware of the extra weight but was still somehow hoping to do a little better around town. But not a big deal, we are happy with it. We took it up to the mountains on a sharp rocky road and we were glad to have solid tires.
* My F-150 has the max tow so it does have the 3.73. I think the Whipple tune and 91 octane helps the mpg.
*Today we did 17 mpg @ 80mph from Holbrook AZ to Tucumcari NM according to the computer. I was dumb and forgot to manually calculate. I will pay attention tomorrow and post that data.
* I am also interested to see difference in mpg between 70 mph and 80 mph.
*Are the factory tunes optimized for mpg or are their after market tunes that might help? The tunes more or less just change shift points and timing or is their more? Could a tune optimized for this larger tire size help? What about better air intake?
*Also if all factors remained the same what do we think the difference in mpg might be between 3.31 and 3.73 axles?
Overall I realize the expedition is heavy and the wheels/tires are heavy. Considering the hp these motors produce and how good these drive I feel like I should be pretty happy with m current mpg. Thanks again for the input!
Left Coast Geek
Mid Left Coast
fuel efficiency tends to go down exponentially with speed. cruising at a steady speed for long distances on a level freeway, the lowest speed that it will stay in top gear will probably give you the best efficiency. 55-60 is way more efficient than 65-70 which is way more efficient than 75-80.
ib_jigged
NW MN
My best highway mileage is in the 55-65mph range. We live in an area with many roads that are still in this range for speed limit, lot of two way roads here in NW Minnesota.
duneslider
Utah
The trips I take have a considerable part of the drive in 80mph speed limits, so I am usually going 85ish with a Velocirax and at least a couple bikes and with that combo I am still usually getting 18-20ish. If there is any headwind at all that number drops pretty good. Not having the rack on usually gets me an additional 1-2mpg at those same speeds. Slower speeds def net better results. It also seems like everywhere in Utah is uphill both ways. I went to sunrise, AZ a bit ago and with some slower speed limits in AZ and some long flat stretches, I got a 22mpg with the bikes on the back.
jjscsix
texas
We get 18.5 around town and easily get 22 on the freeway even at 70-75mph. My experience on many vehicles is that what you lose going up mountains you get back coming down. But as others have said, lots of variables, but you know that.
