98 expy fob (keyless entry)
Racenut
Deming, New Mexico
To reprogram the transmitters,
place the key in the ignition and
switch from OFF to ON eight times
in rapid succession within 10
seconds. After doors lock/unlock,
press any button on all
transmitters (up to four). When
completed, switch the ignition to
OFF.
All transmitters must be
programmed at the same time.
metaldrgn
somewhere
You shouldn't need to reprogram your transmitter...
and you could have figured out how to program it doing a search on google...
Racenut
Deming, New Mexico
People come to this site for help and not for negativity!
And yes some times you do need to reprogram the keyless entry fob after changing a battery. Some times you have to reprogram them for no known reason and that is what this site is for. TO HELP PEOPLE!!!!!!!!!
metaldrgn
somewhere
That's not negativity, calm down.
Check and make sure you have the batteries in the right way and make sure they are making a good connection. You could go to autozone and use the remote detector tester to make sure your keyless entry is working correctly to eliminate other variables.
metaldrgn
somewhere
You also FAILED to mention a few other key points to reprogramming a remote:
1. the ignition switch is cycled from off to run. there is no position labeled on. off would be one click up from lock and run in one more click. the next click is start and you don't want to do that. won't hurt anything, probably just won't work.
2. The biggest thing you didn't mention is the fact that after the doors lock/unlock once you successfully enter the program mode, the doors will again lock/unlock after each remote transmitter is programmed so if it isn't working you won't get that and therefore have a transmitter problem.
Racenut
Deming, New Mexico
SRAIGHT FROM THE 1998 FORD EXPEDITION OWNERS MANUAL
http://www.motorcraftservice.com/pubs/content/~WOWEXD/~MUS~LEN/41/98exdog1e.pdf
PAGE #32
POSITIONS OF THE IGNITION
1. ACCESSORY, allows the
electrical accessories such as the
radio to operate while the engine
is not running.
2. LOCK, locks the steering wheel,
automatic transmission gearshift
lever and allows key removal.
3. OFF, shuts off the engine and all
accessories without locking the
steering wheel.
4. ON, all electrical circuits
operational. Warning lights
illuminated. Key position when
driving.
5. START, cranks the engine.
Release the key as soon as the
engine starts.
THESE POSITIONS ARE ALL THE SAME AT LEAST THRU THE 2002 MODEL YEAR ON THE EXPEDITION!
AND THE DIRECTIONS THAT I POSTED ARE STRAIGHT FROM THE OWNERS MANUAL AS WELL!
CHECK IT OUT FOR YOURSELF : PAGE #58 UNDER THE HEADING - REPLACING LOST TRANSMITTERS
Now if you where talking a model year 2000 or newer than you are correct about the doors locking and unlocking to confirm the fob was programed. But the manual does not list that for the 1998.
Here is a link so that you can access all of FORDS ONLINE OWNERS MANUALS:
https://www.fleet.ford.com/maintenance/owners_manuals/default.asp
NOW WOULD YOU LIKE TO CHALLANGE ME AGAIN! WHEN IT COMES TO GIVING INFORMATION OUT TO PEOPLE I ACTUALLY READ THEIR QUESTION AND THEN DO MY HOMEWORK TO MAKE SURE THAT THE INFORMATION IS CORRECT!
Racenut
Deming, New Mexico
And to this reply, If you would have actually READ the posters question you would know that the only thing he was looking for where the programming procedure.
Also the remark on negativity - why are you going to make a smart a** comment about this person should have used google. This person came to a source to find out information which is the purpose of a FORUM!
X
xBrandonxx
All over
Thanks for the help I'll try the ten times. And to the guy who said tO google search. I did and all the things I found said 8 times not ten. So maybe this will help. But I know what u mean how people ask a question before trying to find their own answer. But that's not the case here. Thanks everyone.
JDMitchell
Fort Leonard Wood
Thanks for posting this, I just programmed a new remote (cycled key 8 times) for my 1997 in about 10 seconds withoug sifting through thousands of google links.
