Ford performance 20" Wheels
bledet
US
I'm looking at the Ford Performance 20" rims for my 2019. Every online fitment guide says they do not fit, from what I beleive is because of the hub size. From what I recall, the Expedition hubs are smaller, so they would bolt up, but possibly be off center. Being hub centric wheels, they make adapters, but could not previously find the proper size for my application. From my research, this should work, as long as you install them properly using the lugs to center the wheels. Find it hard to imagine aftermarket wheels are made with all these different specs.
Hac anyone actually done this process, or are there any experts that can confirm I can make tis easily work by being careful with the installation?
rd618
new york
They fit, the hub is the same size. The only issue is rear, the caps won't pop-in as the expedition rear axle has a longer center bolt that has to be trimmed. just use a carbide tip reciprocating saw, and trim 1/4-3/8 of inch.
