2025 Opening the Lift Gate with the Remote Question
LCField
Spring, TX
My 2025 Active Expedition has a Setting under the Settings Menu to A) Open the Upper Lift Gate ONLY or B) Open BOTH Upper and Lower Gates. I keep setting mine to "Open Upper Liftgate Only", but it still resorts to opening BOTH upper & lower gates... I've tried Saving Profile settings, but the liftgate is not part of the profile settings for either remote. So, my question is, how do I set my liftgate settings in the menu to ONLY OPEN THE UPPER LIFTGATE WITH THE REMOTE, and actually KEEP this setting?IMG_3416.JPG
sixstring
It is as if they don't test each and every feature before releasing the vehicle.
jkp71
Georgia
There was a software update roughly a month ago that said it was part 1 of a 2 part update aimed at fixing the issue. The second update hasn't happened...
Tankboy25
IL
Can have the lower gate open with the top closed so I can carry lumber home?
jkp71
Georgia
Sure, but the top portion won't be latched. Not sure how all of that would work our driving down the road...
Boilerman
mine still opens both even though set for liftgate only. you would think after almost a year after release this would have been fixed.
aggiegrad05
North Texas
Similar to the "open on apprach" issue, this may be a 2025 issue...
My '26 works as advertised: remote only opens the top half of the gate when that option is toggled.
Point being: there is software "out there" that works.
