Air Bag Sensor
covey6
Illinois
My 2003 Expedition gives a "42" sequence on the air bag light which I understand indicates a problem with the front impact sensor. Can anyone give a safe sequence for replacing the sensor. I really don't want to blow an airbag.
sgtowing
Supporting Members
Valrico, Fl
Disconnect the battery before you do anything and don't reconnect till everything is done.
C
covey6
Illinois
That will keep the air bag from going, right? Should there be a waiting period?
sgtowing
Supporting Members
Valrico, Fl
It needs the electric from the battery to fire. just make sure all connections are made and everything is mounted and secure before you reconnect the battery.
Newport News, VA
can he try shutting off the air with the switch in the back along with disconnecting the battery? curious?
C
covey6
Illinois
Hey Thanks. Better Safe Than Sorry. Have a good day.
C
covey6
Illinois
Hey "sgtowing"! Just a follow up. I disconnected the battery, replaced the part, and reconnected the battery. Problem solved! Thanks again for the help.
lmg4513
michigan
My 2003 Expedition is flashing a code 42 also. Can anyone tel me exactly where the sensor is located so I can try check to see if it's just corroded or needs to be replaced.
