2018 Expedition LED headlight conversion
Chris Carl
Maryland
I took the same path as Breaker (Thank you very much for posting videos on YouTube Breaker!) and I am very happy with the results. I am switching out the fog lights to LEDs early next week.
Does anybody know what the specs are for the Fogs? I just tried the H10/9145 Alla Lighting LED Fogs and they did NOT fit. If anyone has links to the correct bulb, let me know! Thanks
16plati
VA
On the front of the lens at the bottom under the bulb it should be stamped into the lens
William Miller
Okemos
This is the LED bulb I just installed last night on my 2019 XLT: https://www.amazon.com/Alla-Lightin...?keywords=alla+led+bulb&qid=1570633918&sr=8-6
Amazon fit guide will tell you it doesn't fit the Expedition, I can assure you it does. Also please note this is the same bulb Breaker used for his fog lights.
byz250f
SE MI
Looking to see what is the best route for fog lights, low and high beam for our 18 expedition. These stock bulbs are pretty sad.
CJJB
Missouri
I have a 2018 Expy Max and want to replace the stock projection headlights as well as the running lights with LED's. I checked Amazon but there are several choices. Anybody replace those stock projection lights/running lights with LED's?
byz250f
SE MI
I would like to know as well
I reached out to headlight revolution and they recomended these two options:
low beam
https://headlightrevolution.com/supernova-v-3-led-headlights-9005-9145-bulbs/
and for the high beam
https://headlightrevolution.com/gtr-lighting-csp-mini-led-headlights-h11-h16-bulbs/
Molaf
Merica
So I installed a set of Hikari Ultra's for the low beam. Excellent light output, clean cut off. However, I noticed that my driver side has a barely noticeable flicker. So with that I figured maybe the bulb was just defective. I order a replacement set and same thing, driver side slightly flickers. Passenger side is fine. I'm going to try the other new bulb that came in the box, but for now I'm hoping it's not something else that can't be fixed easily. Any ideas?
18XLT
Detroit
Bump
ever find a solution to the flicker?
Bmanxx13
Arizona
Bmanxx13
Arizona
I have the same problem with different bulbs, linked above. Mine flicker once in a while. Enough for me to notice, but not enough for me to worry about.
