2006 EB
Replaced Factory Stereo with new Power Acoustik (in a pinch for time), just used the cheap wiring harness while we waited for the CRUX to be delivered. Everything worked fine, with the exception of the sub as we knew we needed the CRUX for that. When it finally came in we switched out the wiring harness and plugged everything back in, no power to new head unit. Checked fuses, still nothing. Ended up buying a PAC wiring harness with interface and rewiring everything, same issues. Ran a secondary power cable, finally got power to the HU. But still nothing at the amp and no steering wheel controls even with the interface. We're at a loss at this point, and its cold outside. Any ideas would be greatly appreciated.
