Jack and Tools What are these and what am I missing? 2013 Expy XLT
00000
FOREST VIRGINIA
UGG THouGHt I'D WaRN Y'aLL My 2008 = 2nd owner
beautiful paint etc. lugwrench showed one complete thru crack upon examination ~ I'm 67 5-11 190 & unsure if
I did this ? Surely recommend traveling w/ a robust
floorjack - wheelchocks + more than one lugwrench Then
(weather permitting) pre valentines practice sessions w/
the fairer sex !
00000
FOREST VIRGINIA
CoMMoN Sense Rule - Don't get under any vehicle by the
side of the road (even w/ multiple jack stands etc.)
unless you absolutely have to !
00000
FOREST VIRGINIA
A FiNaL THouGHT ( HoPeFuLLy ) MiGHT WaNT To BiTe
THe BuLLeT aND uPGRaDe aLL YouR LuG NuTs = I
SPeNT HouRs ReSEaRCHiNG aND FiNaLLy SeTTLeD
oN [ FoRGeT THe BRaND ] BuT oNe PieCe MaDe iN
TaiWaN [ QuaLiTY ReaSoNs ] eBaY MuCH CHeaPeR
THaN aMZN THiS SPeCiFiC iTeM oR I'd HaVe a LiNK
oR BRaNDNaMe HaNDY ~ oF CouRSe : YMMV
JamaicaJoe
JamaicaJoe
Oviedo FL
Yeah it has occurred to me to check the fit of the lug wrench on all the lugs and make sure it is solid. That said, I will pack my Craftsman breaker bar and deep socket set with the kit.
And yeah, I would not bet my life on scissor jacks. The bottle jack that comes with Gen 1 Expy's seems a lot more stout.
2010-2014-only
Anchorage, AK
And a 6" extension to go between the socket and the breaker bar! Couple of 13/16" sockets in case you lose one. If corrosion gets under the "skin" of a lug-nut it will make it swell to where you cannot get a 21mm/13/16" socket on, so squirt them with Corrosion Block or similar every time you have them off.
Staff online
edyk1986
