03 EB a/c in rear not cold.
patch520
03 EB a/c in rear not cold. front a/c is cold. blend door works. High pressure good, low pressure good.
stamp11127
Temple, Georgia
Expansion valve is stuck open or closed if the blend door is not stuck on heat.
drspddmn
Florida
Having the same issue with my rear a/c... just replaced compressor, condenser, and drier but did not replace exp valve. Problem was not an internal compressor failure so I skipped that step. There was no issue with the rear air working prior to failure. Could that still be the issue and how do I determine if the blend door is not working?
