07 4x4 acting up...clunking/jerking...WTF?
Sterling Archer
Olean NY
When in 4hi I often get a clunking/jerking sound motion as if teeth on a gear are skipping. Surface was slush and light mud.
During same instance put it in 4lo and it never went into 4lo...tried it again a few min later and same.
As for the clunking/jerking, is it the t-case or are the locking hub actuators out to lunch?
Replacing wheel bearings this weekend so can take a look then. Dorman has the hub actuators cheap if I need them...
S
Sterling Archer
Olean NY
Will look them over...She's getting a full suspension work-over this weekend...183k on original parts...
FordandPolaris
Saint Cloud, MN
Can't complain with that show. I had mine last about 170k and replaced everything around 180-190. You will notice a huge difference when you do the overhaul.
If it wasn't already on the list, check the rear suspension as well. Basically the same setup as the front minus tie rods.
S
Sterling Archer
Olean NY
Everything is going poly, new struts all around, new ball joints all around, new wheel bearings, the works....Front springs will also be replaced when they finally come in.
