07 5.4 expedition rough idles in park and in gear
lando_l44
arizona
Hey guys looking for some help. So i just replaced my radiator and a coil that was bad. Now when i start the truck it rough idles and when i put into gear it nearly wants to move..i tried replacing the Maf sensor and that made no difference. Could i have unplugged something or what not when disassembling to get the radiator out? I checked all plugs and wiring on the coil and plugs and everything is tight and secure. Looking for some direction or should i tow it to a dealer? Thanks
L
lando_l44
arizona
Also when you turn the ac on it gets worse and you can smell coolant in the engine bay after it idles but i can’t find any signs of leaks
Andy Rubalcaba
Riverside, CA
watcha mean it nearly wants to move? is the RPM spiking up when you go into gear? kind of sounds like a temp idle control sensor ( w/e they would call it for these trucks, I dealt with it and learned the kind of issue for my land rover but the pars are named different ). I believe a crankshaft position sensor ( again, rover had one ) could also effect it but for my rover it was night and day when I installed a idle control valve replacement ( symptoms are opposite, where in park the RPM's climb and climb quickly and in gear it nearly stalls out ). i'm not super familiar with how the ford is setup for that kind of thing, but on the rover there is a idle speed screw, it's an allen hex bolt head and you just adjust the truck's base idle, but i'm not sure if the ford has such a thing or not.
may be useless info, may be the right path, hope more chime in.
L
lando_l44
arizona
It bearly wants to move can’t find the right word to use lol….and the rpm bogs down in gear.i had an issue like this long again in a f-150 and it was the maf sensor, i changed the one and same issue. It gets worse with the ac on for some reason
Andy Rubalcaba
Riverside, CA
yeah that bogging sounds like either an issue with an idle control valve part ( causing irregular air mix which would cause a rough idle, running rich or lean ) or a vacuum leak. do you hear any hissing sounds with the hood open?
Hamfisted
Ft Lauderdale
Can you drive it around the block or so and get it to trigger the check engine light, then read the DTC code. Did you unplug any fuel injectors or other coils when you did your work ? Hear any vacuum leaks ?
L
lando_l44
arizona
I didn’t try around the block i tried backing it out and it was sputtering so i put in drive and rolled it back into garage. I’ll try and drive it around later today when there’s not much traffic going around the neighborhood…and as far as hissing sounds i can’t hear anything really hiss
Trainmaster
Old School Member
Rockaway Beach, NY
How did you determine the bad coil? When were the plugs changed? As Ham says, try to get this thing to give you a code. Sounds like you have a miss or a big vacuum leak. Andy says look for sucking sounds which would show a vacuum leak. And don't rule out that the "new" coil is bad. Some of the cheap ones are bad out of the box. You could have two bad coils now.
L
lando_l44
arizona
I replaced the coil because i had issues with a coolant leak from the radiator and a hose and some pooled on/around the coil. So i undid it to clean it off and make sure none got inside the cylinder area and when i pulled the coil off-the spring inside that makes contact with the spark plug pulled out and broke so i replaced it
Trainmaster
Old School Member
Rockaway Beach, NY
The 2007 had the notorious "two-part" spark plugs that are hard has **** to remove. It's quite possible they were never ever changed. Drive it and try to get it to give you a code. If it's any code involving a miss, get at least one plug out to look at its condition and consider changing them all. That's the simplist place to start.
Some better code readers will give you a "balance" reading that will tell you exactly which cylinders are misfiring and how often. That would save you from pulling a plug to check or trying to get an OBD code out of it.
L
lando_l44
arizona
Thanks i will try to get a code..and if you can could you recommend a code reader worth buying
Hamfisted
Ft Lauderdale
Well, ForScan is free and it's specifically built for Fords. You need a laptop and a USB to OBDII adapter. The Lite version will work on your phone but doesn't have all the test features that the laptop version has. Second choice would be BlueDriver. The software is free but you need their proprietary OBDII bluetooth adapter ( $99 on Amazon ). Third choice would be Autel FX6000 . If you're a computer geek the clone version of Ford's Factor IDS software and adapter module works well but is more involved to get it working right.
ForScan Download Page
Glen B Ashcroft
USA - Oklahoma
i have an 2007 as well, the darn hoses to the rear heat leaked bad and ruined a coil, replaced them all with some of amazon for less then 1 oem, runs great, i would replace all the hose parts and o rings on the rear heat fittings, also have you done the timing chain stuff yet?
BlackBetty
Army
Surprise, AZ
While everyone is talking coil issues I’m gonna dumb it down to an air pocket. Did you bleed the engine cooling system after installing the new radiator? Could be an air pocket in there causing those crazy issues. Kinda weird that you had none of those symptoms, and now this. The antifreeze smell could be the coolant trying to pass, but it’s passage could be full of air. Just a guess.
BlackBetty
Army
Surprise, AZ
…when i pulled the coil off-the spring inside that makes contact with the spark plug pulled out and broke so i replaced it
I recommend using spark plug boot grease to keep the two surfaces from bonding. This will prevent pulling/ yanking on that semi-fragile coil-over-plug boot in the future.
Thing is, if all you did was pull it, and replaced it should be no crazy issues. Hmmm
smahaffy
newport beach
My 07 had the same issue. Check your codes.
1. My MAF went bad.
2. My Catalytic Converter clogged.
the backup bogged down the engine.
Mine ran like that when the big vacuum line got knocked off the back of the intake manifold when I did the torque converter
Also what about your vacuum hubs controls? Vacuum resevoir and solenoid properly hooked up? All that had to come off if you did the radiator.
