14 expedition low/rough idle
Blksmk
Canada/USA
Like everyone has said. Do it yourself. That way you can get more acquainted with your vehicle.
Plati
Yeah ... and save ca$H ... and might find other problems ... and get exercise ... and determine if you were being scammed ... and feel satisfaction ... and know its done right ... and POST PICTURES AND A REPORT ON THE FORUM
rjdelp7
2000 XLT
NY
Bad plugs will have hard starts and poor performance, but the have to be basically shot. I would try spraying the throttle body. They get build up with gunk and starve the engine for air at idle.
Papaboo
Spring Hill FL
I have a 14 Expedition with 65000 miles bought used about 2 years ago. For the last 2 weeks I noticed that while in drive or reverse the idle seems a little low and rough. Took it to dealer and they suggested changing the plugs and tune up for 700 dollars. So before I have them do anything, what else should I look out for that might be something else causing the problem? Thanks.
I have a 2014 Limited and changed to plugs around 70,000 using the Iridium plugs, changed all the filters, no problems. Check each plug to see how it looks upon removal. It will tell you how each cylinder is firing. We added a Flowmaster Delta Force cold air induction, model # 389-615125. Don't forget to change coolant it's due.
Staff online
expresspedition
