170 t stat
16plati
VA
anyone with a 15-17 upgrade their t stat yet? Just ordered a 170 for my 16 looking to see if anyone else has done it
LokiWolf
Super Moderator
Super Moderator
Richmond VA
I know it is only needed for repeatability on the Track. It decreases cool down time, since it opens sooner. Should decrease heat soak a little.
16plati
16plati
VA
Yeah I got it bc these trucks normally run hot and with my 93 perf tune, I’ll be able to pull a bit more timing and squeeze some more power out of her. I wanna see lower coolant temps too bc anytime the truck is cooler it’s gonna make more power. Between that, mishimoto intercooler and pipes, and possibly meth she’s gonna be nice and cool
LokiWolf
Super Moderator
Super Moderator
Richmond VA
Be careful with Meth. It over cools the intake charge and the Motor does goofy things. It has to be tuned very specifically for it.
16plati
16plati
VA
5 star has at least 20 vehicles they have tuned for meth
JUST4FUN
Admin
Il
170 stat ? Will this cause the engine to run in open loop ? What temp does it go into closed loop ? What happens to the cats in open loop
LokiWolf
Super Moderator
Super Moderator
Richmond VA
Just opens at 170 vs Stock which I believe is 190 or 200. Turbos are still just as hot...it will have no effect on the Cats.
LokiWolf
Super Moderator
Super Moderator
Richmond VA
That is great...and I have seen logs from theirs and other tuners, where E30 had better numbers than 93 with Meth, because of how these motors handle that cool of an air charge. They think the motor is in low load, and decreases power. Was just giving you a heads up. The EB motors react a little weirder than most to it. It can be tuned to have the desired affect...but it has to be adjusted for in the Tuning.
ManUpOrShutUp
PA
The trade-off is longer warmup times and increased wear all that time the engine is running below the temp it was designed to run at. If you're driving it like you're at the track all day, every day, I imagine it won't be an issue, but for typical driving I think it makes as much sense as the rice burner stickers.
