B
bedrck46
Guest
if you were reading directly at the switch you should get a steady reading at each position if your not then I would suspect that the switch is bad or your meter isn't reading correctly
check rock auto or e-bay for a new switch
What brand and model meter are you using
Have you tested it on a good known source.
Take and touch the two leads of the meter and see what reading you get.
